It is currently Fri Jul 11, 2025 12:06 pm
PostPosted: Wed Jan 11, 2012 7:19 pm
The early set-up works better, and rattles louder!! Never broke a piston, (or cyl.) after lotsa miles!! :)
PostPosted: Wed Jan 11, 2012 8:23 pm
Yeah, pretty much the same here, Rod. I have 30,000+ miles on early cylinders and big-cutout pistons, both stock and Wiseco, and never had a seizure or breakage. Plenty of rattle though, especially with the Wisecos. The stock pistons I used were being made with small cutouts by the time I needed them, so I used the milling machine to make them into big cutout pistons before I used them.
PostPosted: Wed Jan 11, 2012 8:31 pm
If they're bored and honed, you presumably have the pistons that the bores were matched to. So you not only need to trade, but trade for cylinders and matching pistons of the same overbore diameter. (?)
Jim, that would be ideal, but I'm open and trying to see if anyone has the right cylinders and need to even be interested. If so, then I could see where we stand with pistons, measurements and type of piston. These were bored to Wisecos, but I've not checked the clearances, but at this point I have assumed they are good. These have been together as a set on the shelf long before I got them-who knows how or why they ended up this way.
As the cylinders are now, they aren't much use, so the first thing is to get three to match, and I wouldn't be averse to going up to 2nd over if that's what it takes. I don't have immediate need as I have a couple more sets, but would like to get them sorted out for use, or sale or trade.
I've ended up with a lot of parts, and at some point before long, I want to get rid of some of the excess stuff to get things I need for the couple I'm working on. I have no plans to do any more, I'm getting old and I have several RZ350's and a bunch of Yam XS650's, too. Want to keep the best and get rid of the rest. I'm actively working on one of the H2's now. I need to get a set of your pipes and cdi boxes. :)
John
PostPosted: Wed Jan 11, 2012 9:25 pm
RB, "early cylinders are not portable to later specs" makes sense as adding material to the cast iron liner would be a bit difficult, but can series 2 cylinders be modified to 1st series specs? Has anybody actually tried this? A quick look suggests that it can be done, but I'll have to make accurate measurements to see if the transfer cutaway can actually be modded without causing problems.
PostPosted: Thu Jan 12, 2012 12:04 am
I mod the cut-outs all the time, not a big deal.
PostPosted: Thu Jan 12, 2012 2:42 am
I've heard the early cylinders would crack between the inlet and transfers - never seen it myself - hence the modification.
PostPosted: Thu Jan 12, 2012 3:59 am
have already ride with mix barrels on the past no trouble and the engine was still strong :mrgreen:
PostPosted: Thu Jan 12, 2012 6:07 am
hooktool wrote:
I won't need them until RB sends my heads anyway. :D
John
ARHGGG!!!! - I am SO glad that you posted that, with the loss of the old board I had NO clue of how to get hold of you - or even what your I.D. was :oops: - PM me some contact details :thumbup: Unfortunately, I JUST landed back in England so you won't be getting the heads for a while :oops:
PostPosted: Thu Jan 12, 2012 11:52 am
R.B. wrote:
John
But I still knew how to find you. :) If I had needed them, I would have gotten in touch. No hurry, I'll PM you.
John
PostPosted: Thu Jan 12, 2012 4:07 pm
Zambia wrote:
Pistons for the high transfer cut-outs are....rocking horse poop.
I'm not sure what you mean, Z.
that would be "very rare" jim
