It is currently Thu Jul 17, 2025 3:38 am
 Post subject: 65w headlamp
PostPosted: Sat Mar 03, 2012 5:30 pm
Is the H1e/f/KH500 charging system up to running a 65w headlight, keeping in mind that there will be no battery to charge (has capacitor), and will be using an L.E.D. tail/brake light, turnsignals and L.E.D bulbs in gauges.
There will be no high/low beam. Just an on/off switch
 Post subject: Re: 65w headlamp
PostPosted: Sat Mar 03, 2012 5:58 pm
yes
PostPosted: Sat Mar 03, 2012 6:15 pm
No hi/lo? Is this an HID lamp?
PostPosted: Sat Mar 03, 2012 7:05 pm
no. Its just a halogen.
and thanks Mark.
PostPosted: Sat Mar 03, 2012 7:07 pm
Cool. I was thinking that an HID might not like the idle voltage without a battery.
PostPosted: Sat Mar 03, 2012 7:13 pm
I cant afford the HID kit to upgrade this headlight...... ($400.00 currently). :shock:
and the LED kit is $600.00
PostPosted: Sat Mar 03, 2012 7:15 pm
The LED one is more worth it, if it's well designed, but still WAY out of my price range. A few years will help... you're still young and can wait. :lol: There is a 7" round LED headlamp available for something like $250, but I imagine you're going to use a teeny one, not a 7" round.
PostPosted: Sat Mar 03, 2012 8:26 pm
If you are going to go to a 65W incandescent bulb I suggest you run a large wire dedicated circuit for it. I saw a chart at Daniel Stern lighting a while back and even a 1/2 volt drop effects the light output big time. :(
A relay connected to the standard hi/low switch could be used. Stern sells the relays for this too. This will give the brightest light and not over tax the weak switch/wiring of the original Kaw installation. ;) Just a thought.....
J
PostPosted: Sat Mar 03, 2012 10:47 pm
J
thanks J, The whole wiring harness is "home-made" so I'll be sure to run a larger gauge to the headlamp. And I dont think there is need for a relay since I wont be using the stock iggy switch either.
PostPosted: Sat Mar 03, 2012 11:07 pm
I'd be more concerned putting 65 watts through the hi/low switch on the handlebar, hence the relay suggestion. :)
J
