It is currently Tue Jul 15, 2025 7:37 pm
 Post subject: H2B question
PostPosted: Wed Aug 24, 2022 11:24 am
What am I missing? The hole in the top case goes through to the transmission.
 Post subject: Re: H2B question
PostPosted: Wed Aug 24, 2022 11:57 am
Clutch cable routes through there :)
PostPosted: Wed Aug 24, 2022 12:02 pm
That looks like where the clutch cable housing sits, with the cable extending into the area where the front sprocket is.
Edit: Scully beat me to the ENTER key. :)
PostPosted: Wed Aug 24, 2022 12:40 pm
Just realized that, open due to hydraulic clutch. Thanks
PostPosted: Wed Aug 24, 2022 1:00 pm
Yeah, I have my hydraulic hose run under the engine and up to the slave cylinder too. When you asked about the hole I had to go look at my H2 to remember what's going on there.
PostPosted: Thu Aug 25, 2022 3:46 pm
SoflaH2B - haven't seen any posts from you in awhile!
PostPosted: Sun Nov 20, 2022 7:59 am
What about this hole, down below the carbs? Is it a drain?
WFO for 51 years
1974 Norton Commando 850 Roadster
1974 H2B
1975 Yamaha DT400B
1975 T160
1984 RZ350
2007 Tiger 1050
2014 Rocket III Touring
PostPosted: Sun Nov 20, 2022 2:00 pm
Yes, it's a drain.
PostPosted: Sun Nov 20, 2022 3:15 pm
They often get plugged and the top of the case has so much crud you can't even tell there are holes under there.
Last edited by ThreePipesSmokin on Tue Nov 22, 2022 7:51 am, edited 1 time in total.
PostPosted: Tue Nov 22, 2022 4:39 am
Thank you for confirming. I searched for access on the underside couldn't find them. They are plugged tight, likely from vegetation, outdoor storage. I was going to use a steel wire to poke them out.
Cases being split any day now, so no need now.
WFO for 51 years
1974 H2B
1975 Yamaha DT400B
1975 T160
1984 RZ350
2007 Tiger 1050
