It is currently Wed Jul 16, 2025 5:47 pm
PostPosted: Mon Aug 12, 2019 10:26 pm
Need cable breaket for h2 750 oil pump tab is broken off.
PostPosted: Tue Aug 13, 2019 12:36 am
Drill a hole in it even with the broken tab and safety wire the cable end to it until you find one. I will look through my parts pumps and see if I have a good one.
PostPosted: Tue Aug 13, 2019 12:43 am
Good idea thank you hope i find one i checked ebay nothing yet.
PostPosted: Tue Aug 13, 2019 8:13 am
They can be repaired, and you can even put a tab on in a different place so when you're using 34mm carbs the cable doesn't get bent badly at the end of the travel. Having or knowing someone with a TIG welder helps.
PostPosted: Tue Aug 13, 2019 12:12 pm
How are you Jim still make pipes and CDI boxes
PostPosted: Tue Aug 13, 2019 6:05 pm
Hi Richard. I still do the electronics and plan to keep doing it, but chambers are pretty much on hold for now. I don't have the time any more, and the guy I had fabricating them is too busy himself now.
If you strike out with the oil pump pulley and don't have TIG available, you can make a little loop to replace the broken one, and make it overlap the disk a little. Mark where it goes and mail it to me. I'll weld it on and mail it back.
PostPosted: Tue Aug 13, 2019 6:32 pm
Thanks jim i will need a cdi box for a 69 500 soon
