It is currently Sat Jul 05, 2025 2:42 pm
 Post subject: New Product
PostPosted: Sat Apr 15, 2017 8:40 am
Large carb adapters for the H2. :thumbup:
32 to 39.5mm carbs. Set comes complete with aluminum manifolds, clamps, tubing and allen head bolts.
129.00 plus shipping
 Post subject: Re: New Product
PostPosted: Sat Apr 15, 2017 1:12 pm
Interesting, looks like they tilt the carbs up a bit. Is that for crankcase clearance?
PostPosted: Sat Apr 15, 2017 1:28 pm
That and a straight shot down the port. :thumbup:
PostPosted: Sat Apr 15, 2017 11:14 pm
John,
Going that big on the carbs...do you get a kind of secondary Venturi effect as the mixture enters the smaller intake port? Are they designed to match a reed block or the cylinder. Appears to be the cylinder? Or do the reed blocks neutralize any of that potential? I gotta believe they have to taper down some to match the cylinders?
Enquiring mind need to know!
4Dog
PostPosted: Sun Apr 16, 2017 9:18 am
4 Dog knight wrote:
John,
4Dog
Not really, as the intake port will be matched to the adapter. One plus (beside the straight shot intake) is it adds some intake length/area, this allows for a bit of ram effect from the intake flow, also changes the intake wave timing to the carb. These adapters are actually for the guys running piston port motors.
I do have a Stage II reed conversion for the guys wanting big carbs and reeds. :thumbup:
PostPosted: Sun Apr 16, 2017 4:24 pm
Would they hurt using them with your stage one kit?
They look good, would make carb removal easier, with the 34's a guy has to do a bit of shaving on the carb bowls and I still have some trouble getting the left carb on and off.
Having a straighter shot can't hurt.
I have been thinking of making new spacers on the stage one kit, angled just a bit for these reasons .
Maybe this is the answer I was looking for. :think:
PostPosted: Sun Apr 16, 2017 4:51 pm
I looked, won't work, too different. If you cut a bit off the top of the countershaft cover, the carb comes off much easier.
PostPosted: Sun Apr 16, 2017 6:58 pm
That's to bad... more of a looks thing for me, it looks strange in my mind when ever I look at the cylinders angle compared to carb angle.
Looks like a good product :thumbup:
PostPosted: Sun Apr 16, 2017 7:34 pm
Thanks Joe! :thumbup: I'm not going to do another casting run for a while, but if you don't figure something out, I can probably modify a set in wax before casting.
PostPosted: Mon Apr 17, 2017 12:10 am
I like your work , John you know how to get triples going ,
URs Al in Aus
