It is currently Fri Jul 04, 2025 12:11 pm
Post new topic Reply to topic  [ 78 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8
PostPosted: Tue Apr 19, 2016 2:46 pm
yes, that was the fat spot. I had the right side head off and measured that bore as well.
it also had an L ring piston.
I might be able to get away with a ball hone and new pistons. I''ll have to pull all three and take a good look
at them
PostPosted: Tue Apr 19, 2016 2:59 pm
well according to wiseco there piston is 2.8316
PostPosted: Tue Apr 19, 2016 3:02 pm
2.8346-2.8316=0.003", so Wiseco I guess Wiseco is recommending three thou clearance, where Wössner recommends 0.0027". Pretty close to the same.
PostPosted: Tue Apr 19, 2016 3:53 pm
I cant believe what a difference that is to the old ones.
If I can find rings for the old pistons I could always use them
in this other set of cylinders. They are 20 over now and need to be bored
PostPosted: Tue Apr 19, 2016 11:50 pm
I think wiseco are 30 thousands unless the older are different and I asked about putting wossners in mine when they came out and was told no rebore was neccessary as long as it's a fresh bore
PostPosted: Wed Apr 20, 2016 6:19 am
The older wisecos are smaller. I called wiseco and got the spec on the new ones.
I had a box of old pistons for yamaha free airs and there was an old wiseco
that was way smaller than a new one so it didnt come as a complete surprise.
I didnt pull the center head yet but if the cylinder is in good shape I will hone um up
and put the new wisecos in there.
PostPosted: Thu Apr 21, 2016 12:01 am
you can find older style rings on ebay cheap
PostPosted: Thu Apr 21, 2016 6:58 am
I did see some there
