It is currently Sat Jun 21, 2025 1:59 pm
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
 Post subject: Re: RZ Gap Prep Begins
PostPosted: Tue Mar 22, 2016 1:40 pm
Thanks
I havent.put the little black plastic.frame covers in either. I dont have a belly pan.
PostPosted: Tue Mar 22, 2016 1:43 pm
Ride report:
Ran perfect speedo.needle is stuck from setting so dash has to come back apart.
LH switch is sticking. I will take it apart again...
New gas cap appears to have fixed the fuel leaking from the cap issue.
PostPosted: Tue Mar 22, 2016 4:35 pm
I know where there is a belly pan.
PostPosted: Tue Mar 22, 2016 5:13 pm
I will discuss the belly pan when I see you...
PostPosted: Wed Mar 23, 2016 12:49 am
Perhaps I.will see you soon.
PostPosted: Thu Mar 24, 2016 6:19 pm
After reading up on turn signal malfunctions on RZs and the causes some others experienced I pulled the tank and located the self cancel box behind the ignition coil and unplugged it. Now my previously intermittently operational turn signals work like a champ. I lubed the speedometer and smeared a litte armor all on the edge of the needle to prevent it from sticking again per the Good Dr. Haase. A test ride was taken and all works as advertised.
RZ350 Gap Prep Complete. Thanks to all for your help and encouragement.
RD350 prep begins....
