So I rebuilt the top end on my RGV after it had the typical power valve hitting the piston failure. Used all NOS Suzuki parts and it started on the first kick.
Ran great for the first 3 short rides and then the problems started. Starts first kick and idles great, spits out the crabs when you rev it and won't hold a
steady rpm above idle. Try to ride it and it just loads up. So I have checked the spark, great. All electrical connections and grounds are good, Power valves
are working and it runs no better when you power them to full open. Carbs are spotless clean and all Mikuni parts. Checked the reeds and several were not
closing. Changed the reeds and no difference. The RGV forum is nowhere as active and helpful as our forum so not much help there. To me it's running like a
bad crank seal but the easy starting doesn't make since unless these bikes don't act like a triple with bad seals. Going to try and do a leakdown test.
Ordered a new Zeelectronic box for it but I don't think its ignition but just not sure. Step learning curve on this little motor for sure. Any thoughts guys
