It is currently Tue Jul 15, 2025 2:19 pm
Post new topic Reply to topic  [ 25 posts ]  Go to page 1, 2, 3  Next
PostPosted: Thu Jan 19, 2012 1:43 pm
Do you see any reason why not to use thin walled (14ga/.07")/ largish diameter (.88" OD) STAINLESS tubing to brace the S3 swingarm being fitted to the hybrid?
I'd like to not add another gazillion lbs to the rear of this bike. With some strategic X's, I cant see a prob...
can any of you?
PostPosted: Thu Jan 19, 2012 4:38 pm
Curious as why you want to use stainless? I think mild steel tubing in the same measurments would be enough for bracing, and would also be lighter than the stainless.
PostPosted: Thu Jan 19, 2012 4:55 pm
I have the stainless... :lol:
PostPosted: Thu Jan 19, 2012 4:58 pm
haha....this is the determining factor so many times
PostPosted: Thu Jan 19, 2012 5:00 pm
True, but 304 stainless is only 2% heavier than the the same size piece of carbon steel. :)
PostPosted: Thu Jan 19, 2012 5:31 pm
Tweakers - all of ya - :lol:
PostPosted: Thu Jan 19, 2012 5:54 pm
I would use .065 x.75 personally, but that should work justttttt fine.
PostPosted: Thu Jan 19, 2012 6:11 pm
something like this-ish....
chain clearance is gonna be close with a 50 tooth rear/16 front (using because I already have them!), but it will help with pivot clearance due to the longer shocks......
and why yes that is a tire-iron being used as a swingarm pivot bolt, and a piece of vertical grain Douglas Fir for a front sprocket locator jig! :lol:
PostPosted: Thu Jan 19, 2012 7:46 pm
Is this going to be a bolt on brace?
Was not aware that one could weld stainless to a carbon steel swingarm?
BTW- Before everyone jumps on the SS bandwagon, we tested some bolts a while back with a super precision torque wrench. As I recall, even Grade 3 was MUCH stronger than SS; Grade 5&8 were beyond comparrison.
A piece of 4130 alloy in that size is $26 for 6' from McMaster
just sayin
PostPosted: Thu Jan 19, 2012 7:47 pm
Thats a good enough reason for me :thumbup:
