It is currently Fri Jul 18, 2025 8:11 am
Post new topic Reply to topic  [ 528 posts ]  Go to page Previous  1 ... 30, 31, 32, 33, 34, 35, 36 ... 53  Next
PostPosted: Sat Feb 02, 2013 9:42 am
Walms wrote:
A bit late but a non modified 400 kicker tucks in nice on the H1 motor.
yeah, figured as much.. :lol: All I have laying around is H-series stuff.
PostPosted: Sat Feb 02, 2013 10:16 am
scrambler73 wrote:
Today I heard back from Speedhut and they confirmed that a capacitor will work just fine as long as its regulated to less than 16volts... (well, I hope Jim's R/R keeps it below that!)... :lol:
It will, but if you haven't already, talk to Scott about what's needed to tame the ignition noise.
PostPosted: Sat Feb 02, 2013 5:26 pm
yep...we've already been talkin'
I asked Speedhut as well, and they said that "if" I do run into any issues with iggy noise, they will work through the problem with me. Including sending noise suppressors if necessary. :thumbup:
So far they have been very good to deal with. Great customter service....and I haven't even bought anything yet!
Scott (Looney) was dealing with some warranty issues, and I'm curious as to the outcome?
PostPosted: Sat Feb 02, 2013 5:46 pm
Postal tracking shows they rec'd my tach Wed, Jan 30........Not a word out of them so far......
PostPosted: Mon Feb 04, 2013 10:26 pm
Ordered up my Speedhut Gauge today. Waiting for the "design proof", so we'll see how it goes.
Also, as mentioned above, I needed to order a new K&N filter.. I was able to find one that met all of the required criteria. :thumbup:
The new one has a larger diameter body (more filter area :thumbup: ), offset and perfect diameter intake mount flange, and best part is that it is tapered....which allowed me to cut the elbow a bit shorter to clean up the overall "look".... Everything fits nicely and is easy to remove and install as a complete unit (airboot to filter) so I'll more than likely glue the entire thing together instead of using clamps, similar to what I did on the Denco H1 intakes.
BEFORE: (Old Filter)
AFTER: (New Filter)
BEFORE:
AFTER:
The only thing that bugs me is the Chrome Cap on the new filter, which will probably be painted.
PostPosted: Mon Feb 04, 2013 11:55 pm
You are lucky you got the only tank I made with the side mount petcock......... :thumbup: And just a couple of degrees, and the filter angle will match the frame tubes.
PostPosted: Tue Feb 05, 2013 12:45 am
I might be building another of these bikes... :shock: Slightly different, but with many of the same details. So, we might need to order up another tank...with the same "side mount petcock".... and this time hopefully it comes "pre-lined" with Caswell. :silent: :lol:
As to filter angle, I tried my dagnabdest to run her parallel to the frame tubes, but physics just doesn't allow it. Unless of course I bust out the grinder, body hammer, tin snips, utility knife...... and sadness :cry:
This'll have to do.
and since all of the big crap is mostly done and I'm now down to the small details (mundane things like chain sliders, wire routing, etc), I feel like we've reached "phase 4"....whatever that means?
PostPosted: Tue Feb 05, 2013 7:32 am
it matches the angle of the motor so.. ? looks good to me.
maybe make a 'cover' for the air filter.. triumph bonneville style?
PostPosted: Tue Feb 05, 2013 12:45 pm
Good Point.. yet another "happy accident". :lol:
hmmmmmm.. Not familiar with that cleaner. Any photos???
PostPosted: Tue Feb 05, 2013 1:07 pm
cody do you think you will get less intake noise with the 3 into 1 air filter plumbing rather than 3 seperate pods.
as my h1 with seperate pods/elbows is quite loud and would do this mod if that was the result.
cheers mark
