It is currently Sat Jul 12, 2025 9:54 pm
 Post subject: What Not To Do.
PostPosted: Mon Nov 25, 2013 2:06 pm
Please check under your tank. I got a hole in my tank from the metal clutch cable adjustment ( in the middle of the cable) rubbing and or sandwiched in between the tank and the frame. I must not have noted the last time I installed the tank. Do not let this happen to you. Check it.
Patch with JB Weld.
 Post subject: Re: What Not To Do.
PostPosted: Mon Nov 25, 2013 2:38 pm
Good idea to Always check this - thanks for the reminder as I don't always... What is it with you and leaky gas tanks anyway :mrgreen:
PostPosted: Mon Nov 25, 2013 3:13 pm
bummer. now you can paint the tank green though. bonus.
you can seal that up with some caswell w/out a repaint or a tank strip. good thing you caught it. would hate to see a fireball from the south from OL PODNAH going KABOOM!
PostPosted: Mon Nov 25, 2013 3:59 pm
Amen!!!
PostPosted: Mon Nov 25, 2013 5:40 pm
Nice patch son.
How much gas leaked out before you noticed?
Glad you didn't go KABOOM like the guys said.
PostPosted: Wed Nov 27, 2013 9:44 am
Yeah that could of been Cajun style for sure, hot and fiery. Good catch!
PostPosted: Wed Nov 27, 2013 10:38 am
What is Caswell? I have a small hole from the throttle or choke cable and I used Seal-All. I don't trust it and I'm thinking I should have used JB Weld or something else.
72blue.
PostPosted: Wed Nov 27, 2013 10:46 am
Caswell makes a tank sealer called Phenol Novolac that has proven to be a very good product. I'm sure it would patch a hole fine, but it's sold in a quantity large enough to coat the inside of a tank.
PostPosted: Fri Nov 29, 2013 10:00 pm
Over 10 years ago, my VF500 started weeping fuel from a rust-through spot. A "temporary" repair with J-B held for over 5 years. May still be holding, but I bought a replacement tank so can't say for sure about the repair lasting beyond that.
PostPosted: Fri Nov 29, 2013 10:23 pm
III wrote:
Nice patch son.
It goes "whoosh" :o
BTDT
With my '74 H1 back in the day, I ran out of gas on my way to work ( less than mile from the gas station ). I coasted into a farm ( friend of my grandfather's) and he had gas in a can. No spout but a piece of inner tube.
A little bit dribbled on the tank and ran under. I didn't think it was that much. When I kick it over, it caught fire.
Luckily his wife saw what happened and had a bucket of water ready when I ran up to the porch. I put three buckets of water on it before the farmer put it out with a fire extinguisher.
I got a ride to work and trailered the bike home after work. I cleaned it up and it ran fine after that. :lol:
But it did come off the list of fun things to do :shock:
