It is currently Sun Jun 22, 2025 1:39 am
Post new topic Reply to topic  [ 203 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19 ... 21  Next
PostPosted: Tue Mar 26, 2013 7:23 am
Yesterday was spent troubleshooting the inop turn signals. I changed the flasher unit from the parts bike ... nothing. Mark Haase shot from the hip and scored with a broken soldered end in the LH control switch being the culprit. I went to the parts bike and that switch was installed in a matter of minutes. John Evans fielded and answered my questions about turn signal wiring as well. The indicator bulbs were flashing opposite of the signal selected. It was evident that someone else has been trying to troubleshoot in there at one time or another as the front screws on the plastic cover were 1/2 way out. I swapped the positions on the bulbs and all works as advertised. I also changed the feed line from the oil tank to the pump. Then I had to pick up 7 bred heifers we got yesterday.
PostPosted: Tue Mar 26, 2013 12:31 pm
To sum up: Tim fixed his turnsignals then picked up some fine country women. :shock:
And here they are:
They are 7 months bred and nearly starved, about 300- 400 pounds underweight, whoever owned them didn't take care of them. They were so hungry they were eating the sawdust out of the sale ring. The price was right and the bad weather helped drive the price down further as hardly anyone showed up for the sale. Hopefully the calves will be OK, despite the lack of good nutrition during the majority of the gestation period. We are feeding them up so hopefully all will go well. They are strong , big boned and young, so they will bounce back.
PostPosted: Tue Mar 26, 2013 12:55 pm
What's wrong with Tim's arms? :e11
PostPosted: Tue Mar 26, 2013 5:44 pm
evansje1 wrote:
Belief it or not this bike is magic, ask Evans Ward and the others that couldn't seem to keep this little bike out of the lead while crossing the Skyway :D Even with 40 years of crud in it's plumbing :D
If thats the group ride I rode in, you werent letting any grass grow under those tires. :thumbup:
PostPosted: Sat Mar 30, 2013 7:25 am
evansje1 wrote:
The RD350 swing arm had side to side play so I ordered bronze bushing the fix it but when I took the swing off yesterday it has hardened metal bushings and have no wear. I think all I really need to do is torque the swing arm nut more. Is this an upgraded bushing I have or was that standard on the 350's?
All RDs have the Plastic bushings stock. Mikes XS and other sources sell the brass bushings of the correct size. If you look under the swingarm pivot end covers you should find shims which take up the end play. They may be missing or you need more. Its better to shim than to torque on the swingarm pivot and bend the frame to take up the clearance.
Mark
Obstreperous stink wheels!
1975 Yamaha RD350
1975 Yamaha TZ750
1980 Moto Guzzi SP1000
2019 Triumph T100
PostPosted: Sat Mar 30, 2013 8:10 am
Permanent VT REG arrived yesterday. It's off to the VA DMV this week to get a VA title and plate. VT sent a $3.60 check along too as I over estimated the tax :D :D
PostPosted: Sat Mar 30, 2013 8:19 am
As of this morning.
Mark
The bronze bushing upgrade took out all the play. The way the frame is braced I doubt torque would of moved the frame in. There were shims so I guess more shims were needed. I worked on it till 0100 this morning and just like the exhaust, chain, mirrors, and steering damper. Tim kept texting me last night trying to slow me down :banghead :D I'm about to eat me a bowl of Cheerios and get after it again.
PostPosted: Sat Mar 30, 2013 8:29 am
That was the ride...but I think it had more to do with Rick missing the turn :D
PostPosted: Sat Mar 30, 2013 10:25 am
lovely 73 Evans remember mine on....73 :thumbup:
PostPosted: Sat Mar 30, 2013 9:54 pm
It took 70 days from start to finish. I put main and pilot jets in from an after market kit. Orginal jets are going back in, I knew better.
Once I get the engine tuned I report back on the handling upgrade.
