It is currently Sat Apr 27, 2024 12:02 pm
PostPosted: Mon Feb 18, 2013 10:48 am
Tried the usual suspects, Granger, McMasters and general internet search for suppliers.
I found a few sites that have the length and size but all are bulk suppliers, I'm particularly interested in the longer ones - most are close like the 274mm I found in 280mm.
Can anyone recommend a supplier?
18 92091-020 BOLT ENGINE MOUNTING 10x274 3
19 92091-021 BOLT ENGINE MOUNTING 8x270 1
20 110B0845 BOLT hex head 8x45 2
21 113B10125 BOLT hex head 10x125 2
PostPosted: Mon Feb 18, 2013 12:30 pm
http://www.kawasakitripleparts.com/inde ... uct_id=326
PostPosted: Mon Feb 18, 2013 12:55 pm
Barry, I bought threaded drill rod from Lowes/Home Depot and cut it to length.
PostPosted: Mon Feb 18, 2013 12:57 pm
I am pretty sure Fastenal may be able to provide bolts too Barry.
PostPosted: Mon Feb 18, 2013 2:31 pm
Thanks Ian, bit pricey but there's a reason I like them, shipping and a few extra ones might kill it - but I'll check further. Read on about threads - why I like the OEM/repop ones.
Dale, I've done the thread-all before. Problem is any little bit of play in the frame and the threads wear/oblong the mounts more than a solid bolt would (with threads only at the very end).
Steve, there's a fastenall in town I hit up last summer - they said nothing like I needed - but I just checked their web site and they have something close enough~!
Dale/Steve, one thing I might do is weld/fill the threaded portion where it would be in the mount holes - and then cut them smooth with a lathe. Problem is I don't have a lathe. Solution is I will buy a lathe :thumbup: :mrgreen:
PostPosted: Mon Feb 18, 2013 3:28 pm
There should be a sleeve the right size. Just put in a center piece, and you are good to go.
Users browsing this forum: 0120raptor
