It is currently Tue Jul 08, 2025 1:12 pm
 Post subject: Sealed Battery's
PostPosted: Fri Jul 08, 2011 6:16 pm
Ok guys, I am not spending all this time getting perfect pipes for my triple collection and then freaking out on acid stains,:o :o Can anybody tell me who and how I can get sealed battery's for my H1s and H2s. :D :D :D :D
 Post subject: Re: Sealed Battery's
PostPosted: Fri Jul 08, 2011 6:34 pm
This might get you started: http://www.kawi2strokes.com/forum/viewtopic.php?f=13&t=453
You beat me to it Jim, go have a few more homebrews....... :lol:
PostPosted: Fri Jul 08, 2011 7:25 pm
I just ordered suffix K81 for my H2
http://www.mcmaster.com/#agm-(absorbed-glass-mat)-batteries/=d3d3oq
PostPosted: Fri Jul 08, 2011 7:29 pm
Hard to beat that deal, and good idea. (Made my Dunlop?)
PostPosted: Fri Jul 08, 2011 10:29 pm
Figured 'dI buy the charger while I was at it.
You've got me thinking about the voltage regulator though.
I'm assuming the battery will have max voltage ratings and have never checked what voltage my bike puts out at higher RPM's.
Does anyone make an adjustable voltage regulator for an H2, or are using diodes to lower the possible high voltage (for AGM batteries) the best idea?
PostPosted: Mon Jul 11, 2011 6:31 pm
Wanted to give you this update on lead acid battery abuse.
My battery was nearly DRY although it would keep the lights on with the engine stopped for about 3 minutes.
Filled it with distilled water charged it an amazingly, all the lights stayed on for over 30 minutes!
I stopped the test as I was board and had other work to do on the bike and the headlight is hot (has a replacement bulb)
It will be interesting to see if it holds a charge for any length of time when not in use.
How long is a good stock battery supposed to maintain headlight, tailight and instrument lamps on for?
PostPosted: Mon Jul 11, 2011 6:48 pm
(Amp-hours) / Amps = Hours
Amp-Hours = Amp-hour rating of battery
Amps = load current, in Amps
Hours = hours from fully charged to dead
Non deep-cycle batteries don't like being deeply discharged.
The A-h rating is usually something like a 10 hour rate, meaning if it's a 10 A-h battery, it will run a 1 Amp load for ten hours. It probably won't run a 10 Amp load for a full hour.
PostPosted: Mon Jul 11, 2011 6:56 pm
Thanks Jim but I do know the math behind the ratings.
Just thought that somebody might remember either the Kawa or DoT spec for how long a bike was supposed to be able to support lights with the engines stopped (based on the 70's estimates).
PostPosted: Mon Jul 11, 2011 7:01 pm
For an H2 with a 5.5 A-h battery, and with a 35 Watt (approx. 3 Amp) headlight and a 1A tail light, the math becomes
5.5 / 4 = 1.375 hours
Instrument light will add a little to the load.
