It is currently Sat Jul 19, 2025 9:46 pm
 Post subject: A bit of light relief
PostPosted: Fri Mar 09, 2012 6:41 am
Just for a laugh - you really gotta love E-bay, don'tcha!! http://www.ebay.com/itm/1975-Kawasaki-H ... 5f&vxp=mtr . Oh, there is a matching chain, too :roll: .
PostPosted: Fri Mar 09, 2012 7:40 am
but its oem...
downwind of three mile island
PostPosted: Fri Mar 09, 2012 1:47 pm
Yes, OEM, pre-fully bedded in, and, completely worn out...how unique!
PostPosted: Fri Mar 09, 2012 1:53 pm
Naw - only 50% worn :D Flip it over and run it the other direction :thumbup: :thumbup: :thumbup:
PostPosted: Fri Mar 09, 2012 5:28 pm
Actually, I used to do that on my old motorcross bikes! Double the life! ;)
75 H1
78 CB400II Hawk
78 KE175
PostPosted: Fri Mar 09, 2012 7:40 pm
I just revisited the Sleaze-Bay ad, and, the sprocket is worn out BACKWARDS, appears to have been installed and worn reversed from the correct way, shoulder facing OUTWARD, not inward. Very clever.
PostPosted: Fri Mar 09, 2012 7:46 pm
didnt see the matching worn out rear sprocket...maybe monkeyclaw bought it to flip ?????????????
PostPosted: Fri Mar 09, 2012 9:12 pm
Dave gets the cigar! - did anyone look at the chain......?
PostPosted: Fri Mar 09, 2012 11:14 pm
Some years ago, when my pal Steve Whitelock owned AFAM Sprockets and chains, Dirt Bike Magazine wanted to test a few different brands and types of chains. they had a quandary, as they wanted a bunch of sprockets, a pair for every type of chain. Their test included 6 different brands of chain.
I listened intently to the discussion, then, sat back and came up with a solution, one set of sprockets for the chain testing. They all went bonkers. "can't do that", "different results", all sorts of "Dave is crazy" Steve asked me how I'd do it.
"Simple, Steve. The chain needs to be 120 pins long. 120 divided by 6 is 20 pins in length. Cut 20 links from each chain, and make them into one 120 link chain, continuous, no master links, and run all 6 of 'em at once, ONE set of sprockets. Measure the chains after a set time, and record the results".
That is the exact way it was done, the "Crazy Dave" method.
I think the person selling this sprocket should not sell it, but, put it back on the bike, the correct direction, and wear it out on the other side of the teeth, making it into a 15 point Ninja Throwing Star (shuriken).
PostPosted: Sat Mar 10, 2012 12:01 am
That's funny, Dave. I actually have a friend who wore his KZ400's rear sprocket so much that you couldn't reverse it. It wore so much that the tops of the teeth broke off completely so it was just a bumpy disk. The funny thing was that I had to point out the problem... he hadn't noticed. I guess the KZ400 engine didn't put out enough torque to make the chain slip.
Your "test chain" idea was very clever.
