It is currently Sun Jul 13, 2025 9:41 pm
PostPosted: Tue Mar 06, 2012 3:31 pm
Here is the "poop" on the RIK/Mitaka pistons. I just got a set in from Reproductiondecals, first over 400.
They came with Riken rings.
The wrist pin is 14 mm instead of the stock 15, but comes with a bearing to make up the difference.
The clips are a strange "G" type.
I haven't checked the rings in the grooves yet.
No directional arrow
The piston edge is approximately 1mm lower than stock.
This takes the compression from 6.5:1 to 6.32:1
Compression goes from stock 143 to 139psi
This adds about 4.4 degrees to the exhaust timing
It adds about 5.5 degrees to the transfer timing
PostPosted: Tue Mar 06, 2012 4:36 pm
I thought you wanted forged pistons?
John
PostPosted: Tue Mar 06, 2012 4:58 pm
John
This is for a customers engine......
PostPosted: Tue Mar 06, 2012 9:35 pm
There are cheap Honda pistons on e-Bay that also have that type of clip. They should be easier to install...
Trevor
