It is currently Sat Jul 19, 2025 12:09 pm
Post new topic Reply to topic  [ 528 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17 ... 53  Next
PostPosted: Wed Feb 01, 2012 6:25 am
Did you use any sort of internal baffling to counteract oil slosh Cody?
They always run best right before they stop for good...and it was just running great...
PostPosted: Wed Feb 01, 2012 11:07 am
Neville Lush wrote:
Think of how much weight you would have saved by using premix :shock: Tank, oil,oil pump, crankslingers etc etc :) :)
I did think of it! A "normal" ride for me usually consists of at least one, and somtimes up to 3 fuel stops. To carry oil is a pain
That said... I did tell Dave to leave the Crank slingers off.. :twisted:
You know... Juuuuuust in case.
PostPosted: Wed Feb 01, 2012 11:22 am
m in sc wrote:
inner fender? :thumbdown:
yes sir :thumbup:
here's the "mock-up" fender...which is actually the other half of the stock H1 inner-fender I used on the KH750 7 years ago :lol:
problem is that this half was really beat up, so I ended up cutting up another nice one for the bike. :oops: I actually have an NOS one, and am soooooo tempted to use it :lol: I'll probably try some of that Krylon Fusion paint first. Ive read that it stands up very well on MX plastics as long as you dont spill fuel on it.
and who says you cant cram a 160 tire on an S3?? :e11
no Pete, no baffle in the tank itself. The filler bung is about 1 1/2" ID, but the actually hole cut into the tank is about 1", so it will act as a "slosh baffle" at least keeping the oil from trying to come out the top. I wont be jumping this bike often so shouldn't be a problemo.
PostPosted: Wed Feb 01, 2012 12:01 pm
I know you are going for light weight, but wood struts??????? :lol:
PostPosted: Wed Feb 01, 2012 12:12 pm
one strut, like the KR250.
its from a "hybrid" cross-polinated balsa/rubber tree, so not only is it light weight, it has surprisingly good compression and rebound damping.
PostPosted: Wed Feb 01, 2012 4:09 pm
The Krylon fusion actualy holds up really well, and should suit you fine for that application. The biggest thing I found with it when I had panels on my dirtbike painted, was rub areas, like where my mx boots would always touch the paint would rub off easily. Branches and brush would also leave marks and if hit hard enough by it would take the paint off. This is pretty much what you would expect in those conditions anyways.
I have also used it to paint faded black plastic wheel flares and other pieces on my old pathfinder. After 2 years they still looked suprisingly good. I never had any adhesion problems with the paint, it always stuck very well.
PostPosted: Mon Feb 06, 2012 5:06 am
:D :D You know me Cody, had to ask. BTW where are the 20mm holes drilled in the wood struts....
PostPosted: Sat Feb 11, 2012 3:48 pm
just wondered how heavy my bike was, oil in engine with an empty tank 350 pounds useing two bathroom scales one under each wheel. Im also thinking about removing one of the two discs and caliphers off the Kaw 636 front end. Do i realy need all that brakeing power?.
PostPosted: Sat Feb 11, 2012 3:55 pm
Not bad Henry. :clap:
I got 376lb with an almost full tank, so we are close, but you have the H2 lump. And sure, 2 modern discs are way more than necessary.
PostPosted: Sat Feb 11, 2012 9:40 pm
I read once that you could get an accurate weight using one bathroom scale by putting the front wheel on first, taking the weight, then putting the rear wheel on and adding the 2 together. Can anybody confirm that this will work?
