It is currently Sun Jul 13, 2025 1:11 am
PostPosted: Wed Jan 18, 2012 8:42 pm
Dale, what brand of rum do you recommend for someone who'll be posting?
Bacardi Lite
PostPosted: Wed Jan 18, 2012 8:46 pm
I'm willing to give it a try!
PostPosted: Wed Jan 18, 2012 9:06 pm
m in sc wrote:
2 pickup system? have them on the s2 with an H1e ignition. green lead on the coil goes the three 3 wires that go to the 'grounding' harness (blue, green, black), which in turn goes to the brushes that are on the alternator rotor/ 'distributor'. white wire which comes from the cdi connects to the 3 black terminals. but they will work either way on the mini coils.(talked to jim about this last year at some point)
Perfect!
thanks Mark (and guys)
gutting the wiring harness..... (no horn, signals, high/low beam) Will have nothing other than an ON/OFF switch and a couple of brake light switches.
PostPosted: Wed Jan 18, 2012 9:09 pm
Better make that the white with red stripe wire from the CDI. The white one connects to the signal generators.
yep, I understood it to be the white/red-stripe!
even though I are not a lectrishun.
PostPosted: Wed Jan 18, 2012 9:52 pm
its the ash bark colored wire with the red sap running down the side. :D
nice spaghetti! ps, use the horn button as a kill switch. saves space and weight and junk.
PostPosted: Wed Jan 18, 2012 10:00 pm
Im just going to leave a wire dangling, and ground to something whenever I wanna shut the bike down....
PostPosted: Wed Jan 18, 2012 10:07 pm
I did that on my KH400 back in the day for drag racing, it's a push button clutch! :o
PostPosted: Wed Jan 18, 2012 10:52 pm
Bet yer gonna go with Fred Flintstone brakes too eh?
Get good soles put on yer shoes Cody.
PostPosted: Wed Jan 18, 2012 11:44 pm
Or just pull up, stop, and drop the clutch at idle for shut off
Show that rebel side!
PostPosted: Thu Jan 19, 2012 6:36 am
aw hell, just get some self tapping screws and mount this to the side of the gas tank. Get some of that good wire from the kraco tape-deck speaker wire and hook it up. :thumbup:
