It is currently Mon Jul 14, 2025 12:28 pm
PostPosted: Tue Jan 10, 2012 8:52 pm
if not.... are there any known bolt-on caliper "upgrades" for the later KH/KZ lowers????????
PostPosted: Tue Jan 10, 2012 9:18 pm
Probably the same set up as the S series?.......... :?:
PostPosted: Tue Jan 10, 2012 9:26 pm
Sorry....I can't be much help....I put an h2 front end on and did the EX upgrade.....
http://i949.photobucket.com/albums/ad331/bradway_bucket/2011-03-28195435.jpg
" Do all you can and do it the best you can". -Col. Sanders
PostPosted: Tue Jan 10, 2012 10:15 pm
from what I understand (from a post on the old board where one of the Canadian boys made some KH400 brackets), they are different, but I do not know that for certain.....
PostPosted: Tue Jan 10, 2012 10:24 pm
Hey Cody, ask Andrew (Walms) as he was the one who had some KH400 adapters made.
I think I have one here somewhere that I bought from him 2-3 years ago.
PostPosted: Wed Jan 11, 2012 12:48 am
I suspect the 400 (with its smaller 34mm tubes) will have different disk to fork clearance than the KH500. As such, it may be only the mounting ear bolt spacing that is different from the KH to H1 (should be easy to make a H1 style (flat plate) adapter with the needed KH bolt spacing)
J
