It is currently Fri Jun 21, 2024 3:19 pm
PostPosted: Sun Nov 27, 2011 7:02 pm
Here's some pics of my project. thought I'd throw some up so everyone that's been helping me out can see what they are trouble shooting!
The engine is a '72 H2. Stock bores. Crank was rebuilt this summer. Jetting is stock (need bigger mains though). Exhaust is modified Fast By Gast chambers.
The frame is a '94 Suzuki Katana 600. Original engine was toast. This frame has worked well since the engine is cradled by a removable sub-frame. That makes it really easy to work the Kawi engine into it.
Chain is a 520 unit with a 10mm offset drive sprocket from Fast from the Past. I should have gotten an 18mm offset, but the side-cover of the engine wouldn't handle it. The chain seems to flex enough that it isn't a major problem, but I'm sure that sprocket won't last long. The rear sprocket is a custom unit by me. I couldn't find a 520 katana sprocket, so I just took the 530 one and started grinding it thinner. Oddly enough, it works!
Clip-ons are stock for the katana, just moved them under the triple clamp. Cables are all stock H2, just cut shorter and new ends soldered on. Oil tank is one that is purchased from USPlastics.com. I installed a 'low oil light' switch that is tied to the 'high-beam' light in the headlight bucket. Custom wiring harness with Weatherpack connectors throughout.
Jason
72 h2 in a 93 Katana
03 cbr600rr
80 kz750 ltd
94 pw50
PostPosted: Sun Nov 27, 2011 7:04 pm
Jason
03 cbr600rr
80 kz750 ltd
94 pw50
PostPosted: Sun Nov 27, 2011 7:09 pm
Thats pretty neat, you do good work :thumbup: , I'd like to ride that one for sure with its old school power unit and the new school brakes and suspension it would be an interesting ride to say the least....
PostPosted: Sun Nov 27, 2011 7:10 pm
Jason
03 cbr600rr
80 kz750 ltd
94 pw50
PostPosted: Sun Nov 27, 2011 7:12 pm
It's a lot of fun, the little I've gotten out on it. Steers very well and the riding position is sporty but not insane like my CBR600RR. It's a nice compromise
thanks for the compliment!
Jason
03 cbr600rr
80 kz750 ltd
94 pw50
PostPosted: Sun Nov 27, 2011 10:53 pm
i also used a Katana rear wheel. could not get the H2 sproket to fit the wheel so i made my own cush drive.
PostPosted: Mon Nov 28, 2011 2:41 pm
You must have a mill in your garage!
Jason
03 cbr600rr
80 kz750 ltd
94 pw50
