It is currently Sat Jul 19, 2025 7:17 am
 Post subject: '74 H2B kicker question
PostPosted: Thu Oct 13, 2022 7:41 pm
The single post type boss versus the double shear clevis design. I'm not so much interested in perfect originality, rather, it's scraping the FBG chamber. If it's wrong, I want to get more clearance. I've seen both pictured. Here is what I have: Image
WFO for 51 years
1974 Norton Commando 850 Roadster
1974 H2B
1975 Yamaha DT400B
1975 T160
1984 RZ350
2007 Tiger 1050
2014 Rocket III Touring
PostPosted: Thu Oct 13, 2022 7:48 pm
WFO for 51 years
1974 H2B
1975 Yamaha DT400B
1975 T160
1984 RZ350
2007 Tiger 1050
PostPosted: Thu Oct 13, 2022 9:45 pm
I don't know anything about kickstarter levers other than it's not like the one on my '72, but can the chamber be moved in to clear it? I cut open and changed the cone angles at the welds of my Wirges chambers back in '79 to make clearance. With all the reproduction Dencos I made I made sure there was clearance, whether or not the originals cleared.
PostPosted: Fri Oct 14, 2022 4:26 am
Yes, I will if I have to. Right now I have bigger fish to fry with the center pipe. Under hard braking, the fender hits the header pipe.... hard enough to LOCK the steering.
WFO for 51 years
1974 H2B
1975 Yamaha DT400B
1975 T160
1984 RZ350
2007 Tiger 1050
PostPosted: Fri Oct 14, 2022 8:35 am
Yeah, that's pretty bad. To start, it might be worth measuring the head pipe lengths to see if they're all the same, or if the middle one is longer.
PostPosted: Fri Oct 14, 2022 8:49 am
A kick start lever off a Kawasaki KZ750 twin fits the splines perfectly and might be a possibility for clearance needed.
“Jeff and Chris are THE MEN!”
RIP John E. Evans
PostPosted: Fri Oct 14, 2022 7:39 pm
A KZ900 LTD front fender will provide clearance. Also consider increasing the fork spring rate or lowering the fork tubes in the triple clamps - but not too far.
PostPosted: Mon Oct 17, 2022 4:35 pm
If you take the pipes off, you can grind the "slip-on" part of the header down on the centre pipe. I had to do this with FPP pipes. You can take easily 1/4" off and it will clear the fender. I checked clearance before test riding mine and it was fine until I was cornering under hard braking!! Bike went straight across some guys lawn!
As for the kicker - my H2C had Cast pipes and the previous owner had bent the stock ticket to curve perfectly around the pipe.
PostPosted: Tue Oct 18, 2022 8:21 am
That's what I had in mind, trim the pipe where it slips on the spigot.
WFO for 51 years
1974 H2B
1975 Yamaha DT400B
1975 T160
1984 RZ350
2007 Tiger 1050
PostPosted: Tue Oct 18, 2022 8:22 am
That's good to know, thank you!
WFO for 51 years
1974 H2B
1975 Yamaha DT400B
1975 T160
1984 RZ350
2007 Tiger 1050
