It is currently Tue Jul 15, 2025 10:29 pm
PostPosted: Sun Aug 11, 2019 11:03 am
https://vintagecarleds.com/7-inch-round-headlights/
Click on products
Under 7" Round Headlights
VCm3 Series
VCm3-7" LED
I purchased this Head light for the H2's. It is a direct fit. The lights far out shins the stock light and the standard Truck bulb. It also has a nice pattern. Don't know how long they will last but I like them a lot.
You can purchase a set of two or just one. One is 109 dollars. Two is 209 dollars. You can also purchase the bulb by itself. Look for the promo code (thanks10) for 10 percent off.
Now the BULB only will also change out with the bulb in the RZ 350. Talk about a difference.
Inside bucket you will need if you don't have an H4 connector 3 prong female plug.
I have a picture of High and Low beam from the RZ that I changed just the Bulb. I could sent to someone if they want to attach it to this post.
Iron on the Bayou.
PostPosted: Sun Aug 11, 2019 1:48 pm
Send away.
PostPosted: Sun Aug 11, 2019 6:34 pm
I got your phone message, but I don't have an email from you.
PostPosted: Sun Aug 11, 2019 8:09 pm
Nice - looks very close to stock (compared to my Nighthawk)
PostPosted: Mon Aug 12, 2019 8:24 am
Thanks for the research, link, and your input on this.
PostPosted: Mon Aug 12, 2019 9:29 am
Here is the picture.
PostPosted: Mon Aug 12, 2019 9:53 am
From Iron, new LED bulb installed in his RZ350
PostPosted: Mon Aug 12, 2019 11:05 am
I'm sure it will be manageable, but do you know what the draw might be? I'm sure it will be lower than the incandescent candle we currently have on H2's
PostPosted: Mon Aug 12, 2019 11:44 am
Wattage
16W
Voltage
DC 7.3V – 24V Full Brightness, DC6.3V -7.2V 60% Brightness
PostPosted: Mon Aug 12, 2019 11:48 am
That's a nicer pattern than my Nighthawk (TruckLite).
