It is currently Tue Jul 15, 2025 7:21 pm
PostPosted: Sun Apr 07, 2019 3:40 pm
I'm calling it the H1/H2 because "H1 with an H2 motor" is a long description.
The bike has been on the road for a few years since I rebuilt it. It has a mild port job by Spec2, Higgspeed pipes, stock mikuni's with Ivan's carb kit, UFO's and intake runners.
There have been leaks around the carbs and at the oil banjo connections. Mikuni needle seats and valves with viton tips are a winner, no more fuel leaks! Mikuni 786-15005-2.5 purchased on e-bay for about $15 per carb.
Stat-o-seal washers on the banjos have stopped the leaks. I went to a local hose supply store with the appropriate bolt, they located the proper size stat-o-seals and I bought a set for 61 cents per washer.
The bike was surging a bit at 1/4 throttle. A washer under each needle raised them half a clip and cleared up the surging.
Current jetting for the H2 motor is:
112.5 mains
Needle at the center clip + washer.
17.5 pilots, air screws 1 1/4 turn out.
This is my favorite bike for riding. It has H2 power and it's easier to maneuver than an H2. The handling is a bit wobbly at speed, it might be due to the swingarm or its bushings. I'll check it out someday. The front end has tapered roller bearings. Koni shocks.
Here's a pic I took yesterday and edited with an app called "Prisma".
PostPosted: Mon Apr 08, 2019 8:08 am
That is awesome.
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Wed Apr 10, 2019 6:27 pm
Cool image, and glad to hear you "fixed" all of the inherent H2 issues. :thumbup: :thumbup: :thumbup:
PostPosted: Sat Apr 13, 2019 4:00 pm
Cool deal that you got the issues worked out. :clap:
PostPosted: Sun Apr 14, 2019 10:44 am
Excellent post! I miss this board so much... I wish Facebook never existed! :roll:
PostPosted: Sun Apr 14, 2019 1:38 pm
If you have a favorite picture of your bike and want to see how it looks after editing with Prisma, send me a PM with your e-mail address. Then I will send you an e-mail, you can reply with your photo attached.
