It is currently Sat Jun 15, 2024 5:10 pm
 Post subject: H1 distributor cap
PostPosted: Tue Jul 31, 2018 11:49 am
I just realized I used my nos distributor cap on the bike I built for Leroy a few years back. I could use an nos cap if anyone has one for sale. Thanks again!
 Post subject: Re: H1 distributor cap
PostPosted: Fri Aug 03, 2018 12:37 pm
I finally found an NOS cap.
PostPosted: Fri Aug 03, 2018 2:33 pm
Just for info, where, and how much?
It sure would be a benefit for the triples community, if someone that knew how to do it, make molds, and new top,quality caps and rotors. With all the new tech, like virtual,printers, making permanent molds for the parts and the other pieces, it would be a giant benefit to the triples faithful.
PostPosted: Fri Aug 03, 2018 4:27 pm
I actually found two, the other one was $600.
https://www.ebay.com/itm/NOS-OEM-KAWASAKI-ROTOR-AND-CAP-21141-001-21142-002-H1-MACH-III/253333089704?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
PostPosted: Fri Aug 03, 2018 5:20 pm
YIKES, highway robbery. Someone with casting experience needs to step up and reproduce these caps and rotors.
There were three different rotors, and two different caps. The first rotor was retained on the shaft with a screw, the green rotor, and there was a bulletin when the second design came about, which was a slide on, brown color. To change a green rotor, the clutch cover had to come off, then, brown was developed. Instructions on the service bulletin for change over were, the green rotor was literally broken off the shaft, screw removed, brown rotor slid into place. Last design used a larger diameter shaft, black slide on rotor, and black cap. The brown and black rotors were called QD rotors, for "Quick Detatch". The QD rotors and black cap were considerably more di-electrically stronger, lived longer. The green, brown rotors fit what was described as utilizing a "28mm shaft", the black one "31mm".
I am sure this info is on Dale's info pages.
