It is currently Mon Jul 21, 2025 4:42 am
Post new topic Reply to topic  [ 121 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13  Next
PostPosted: Fri Nov 24, 2017 4:11 pm
Looking for a good instrument pod with the little plastic color warning light lenses. I have the bulb harness, ignition set, tach and speedo but nothing to put them in. Looking for H2b/c
PostPosted: Fri Nov 24, 2017 4:42 pm
I have everything.
Email me below.
PostPosted: Fri Dec 08, 2017 11:24 am
Thanks for the purchase
quote="pmcburney"]Righto then...
Looking for a decent front disc (for my twin disc conversion at some stage), the small right angle bracket that holds the rectifier/diode doodad to the battery box on the H2s and a positive battery cable (the one split into two, a red wire and a white wire).
Would also like the two 10mm x 125mm engine bolts, and one of the 10mm x 274mm engine bolts complete with a set of the five original 10mm x 1.25mm metric-fine friction-locking nuts, and a good, complete kickstart lever if such a thing exists!
Ta
Paul[/quote]
PostPosted: Fri Dec 08, 2017 11:25 am
Thanks for the purchase.
quote="H-nube"]Looking for a good instrument pod with the little plastic color warning light lenses. I have the bulb harness, ignition set, tach and speedo but nothing to put them in. Looking for H2b/c[/quote]
PostPosted: Mon Jan 01, 2018 5:04 am
GUTS wrote:
Do you have an undamaged/re-paintable set of S1C fork ears?
Do you have undamaged / repaintable set of fork ears for KH 250 A5 S1B/C needed really badly.
Also mint undamaged exhaust for same, don't mind if they need rechrome.
Also Tank/Tail/Side panels for same...
Thanks Steve
PostPosted: Tue Jan 02, 2018 3:39 pm
I have some of it. Email me below.
PostPosted: Sat Feb 24, 2018 6:20 am
E-mail sent.
Really need the undamaged fork ears in perfect condition for S!B/S1C/KH250A5 Thanks
PostPosted: Mon Feb 04, 2019 6:12 pm
Do you have a complete rear brake lever and the fasteners for the torque arm (the pin at the front and the bolt, washers and nut for the rear) for a '72 H2?
'66 T20
'72 H2
'74 GT750L
'76 RE5A
'80 GS1000ST
'82 GSX1100SZ
'82 GSX1100SXZ
'86 RG500G
'09 DR650SE
'10 GSX1300R
PostPosted: Tue Feb 05, 2019 6:16 pm
gd day sir,have you got a complete headlamp for a 72 s2 that would be with the hi beam in the shell qegards from jim
PostPosted: Sat Jun 06, 2020 11:26 am
I Still have plenty of triple parts. Email me with your needs, picked up another 2,000 pounds of triple parts. Text 831-710-1194
Triplestuffkawi@gmail.com
Triplestuff.net
