It is currently Sat Apr 27, 2024 8:38 am
PostPosted: Sat Sep 09, 2017 4:35 pm
Running in my new race H1 clutch slipping big time on the pipe. I think this engine will make good power. Medium ported, 34s, chambers, Squished correctly, slightly higher comp on Avgas.
I built everything from scratch but didn't need to split cases. I think the clutch is stock, I did inspect the fibers, within spec.
Probably has stock springs as it feels light. stock actuator.
Question is...what is the best setup?
I don't think I have time to add a fiber as that requires machining? Don't have much time left. going to miss rd1 as it is.
Question....are early and late springs different?
I have some very stiff (gold Barnet springs I think) from my late H1 spare.
I can also use my sytech actuator from my street bike. Can get EBC frictions quickly here.
If there is a definite best setup I do have just enough time if I order now.
Bikes got some stonk. jeez I can build a good engine! :lol:
Cheers.
PostPosted: Sat Sep 09, 2017 5:37 pm
If you have the ball bearing release, use it and add the 5 Barnette springs. New fibers are a good plan also. soak in oil first. :thumbup:
PostPosted: Sat Sep 09, 2017 7:12 pm
No I don't have ball bearing release. But I have the moded sy-tek (hole moved in) I will use that.
Thinking on ordering Barnett Kevlar frictions. If they are anything like the EBC Kevlar ones I put in my FZR1000 race bike they will never slip. In fact they were so good I had to take them out because I couldn't get good starts. The bike would either nearly flip of the line or bog. everywhere else on the track they were great.
Anyone here tried the Barnett Kevlar frictions?
PostPosted: Tue Sep 12, 2017 4:28 pm
I've been using Barnett Kevlar frictions in my H1 for eight years now (approximately 60 000 km). It's a 15 plate H2 kit from Barnett (8 frictions and 7 steels). No slip, no drag. I can shift down while standing still. The tabs on my frictions are getting worn now so I'm going to contact Barnett to se if I get me a new kit.
PostPosted: Sat Sep 16, 2017 12:23 am
Thanks. ive ordered some kevlar plates. on there way. but i have bigger problems...........jetting.
