It is currently Tue Jun 17, 2025 2:54 am
Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12, 13 ... 20  Next
PostPosted: Mon Jun 12, 2017 3:21 pm
Amazing work and dedication to this resto :clap: Will follow this thread, for sure.
Very inspiring !
Peter says:
Keep the revs up !
Bikes:
H1 Candy Red, 1970
Moto Guzzi Daytona 1000, 1992
PostPosted: Mon Jun 19, 2017 10:24 pm
Thank you.
Got a stainless pipe welded and formed tonight. This is in 304 annealed, mirror finish, it formed as well as mild steel, and no welds split. I'm learning more about this as I go, and leaving the tricky center pipe until last. That one might have to be formed and then cut and rotated, I'll see. I did not find any mufflers, stingers that suited this well, wrong shape, size, etc, so will make my own as well, I have all the materials for those now.
PostPosted: Wed Jun 21, 2017 5:54 am
I love the look of hydro formed pipes, can't wait to see the finished product.
The air box is going to be very nice as well…3d printing has opened up a whole new world!
Great stuff your doing :thumbup:
PostPosted: Mon Jun 26, 2017 10:36 pm
Didn't get a whole lot done last week because I had to work the Road America race event. Got the pipe fit to the header and the main mount made and tacked on, fit with it's rubber mount. I was considering not running a front pipe mount but I think without that it will work the cylinder-to-pipe seal a lot and wear the O rings out.
PostPosted: Tue Jun 27, 2017 9:15 am
DGA wrote:
Didn't get a whole lot done last week because I had to work the Road America race event. .
Indycar? Was a good race, I love that track.
PostPosted: Tue Jun 27, 2017 11:34 am
Yes, the Indy car event. I did Indy car for decades, these days an event mechanic on the Mazda pro cars, gets me out of town for a few days and is a nice, but hard work, break. Thursday was a 7am till 12:15 am day....
PostPosted: Sat Jul 01, 2017 9:43 pm
Working on the mufflers now. 3" diameter stainless tube, 10.5" long, 1 1/8" inlet, outlet tube. Has CNC ends to save weight and keep the muffler volume up.
PostPosted: Tue Jul 11, 2017 1:08 am
Got the second pipe finished. I made both outers the same, as in they are both positioned and mounted the same, the inner is the lower one, which made sense I thought. Trying to mount the center one in the rear is not so simple, will probably end up doing something similar to the stock mount, just lighter.
PostPosted: Wed Jul 19, 2017 11:15 pm
Got the exhausts finished finally. I was able to use the same chamber shape for all three. I think I could still use a centerstand, if I had one that is, might just make one, simple enough. The bike is close now, have a new rear DID rim and spokes, so will pull the wheel off and bead blast and polish the hub then lace the new rim onto it. My brother had rebuilt the front wheel, but there is a little surface rust on the rim, but it's not bad for now. I bought a stainless case regulator off Jim at lakeland, don't want to cook my new AGM battery, need to fit that still. Put the tires on it. Then it's put two stroke oil in it and bleed that through, gear oil, a light two stroke mix in the fuel and see if it runs.
PostPosted: Thu Jul 20, 2017 5:14 pm
Great to see you having a go at it yourself and succeeding. :thumbup:
