It is currently Sat May 11, 2024 1:54 am
Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed Apr 26, 2017 5:22 pm
On the vibration I was concerned about this when I built th kaw and the 180 4 is not bad for vibration (bloody awful for surge) How would this really feel on a street bike. ? I mean would it be bad like an h2. And sorry what's crank whip
PostPosted: Wed Apr 26, 2017 10:02 pm
180 has cancelling firing, 1/4, then, 2/3, etc. Vibrations created on each end cancel each other for the most part.
The 90 degree engines have 1, 2, 4, 3 firing. This sets up vibration on one side of the engine, goes to the outer end of the other side, and creates an opposite vibration, then repeats, etc. Water in a jar would raise on either side, then down, and middle would lift, fall, over and over, cancelling vibration.
If you can imagine this, if you had four hands, and all were in front of you, both outer hands would lump up and down together, then, when the outers were down, the two inners would be up, then alternate, fairly even, not a lot of "vibration", this is the 180.
Now, same four hands, left outer, left inner, right outer, right inner, repeat, it is like a wave of liquid moving back and forth in a jar, left to right, then again, left to right, all with one operation between the sequence, but more violently, and no cancelling of pulses.
This is a way too simple answer to a very complicated situation of firing pulses.
PostPosted: Thu Apr 27, 2017 11:43 am
You think it would make much difference depending on the firing order. I'm figuring I'll have to use 1324 or 1423 mine will be 2 180 cranks. Sounds like power production or quality wasn't an issue or at least not much. Either of you have experience with o ring heads. Seems to be highly recommended on the yamahas. Even the air cooled ones.
PostPosted: Thu Apr 27, 2017 11:49 am
As was said, Honda tried it, and they ain't skimpy in the engineering department, and only used it one year, with a great deal of rider and mechanic consternation of it. Even 56 degree "big bang" 4 stroke V4's use a 180 degree firing order. ALL the two stroke V and Square 4's used the 180, some were tried with the re-phased 90 degree, in various configurations of firing order, and ALL went back to the 180 degree phasing.
PostPosted: Thu Apr 27, 2017 12:02 pm
My brother raced an '84 RZ350 Yamaha, it was 180 firing of course. We noticed the cranks were splined together, so pressed them apart and then back together as a single, wanting better traction hard over in a corner. We found Yamaha had balanced it as a pair of cylinders, not as two individual singles, and it vibrated so bad we put it back again.
PostPosted: Thu Apr 27, 2017 12:14 pm
PostPosted: Thu Apr 27, 2017 12:20 pm
Sorry for the double post. Any thoughts on the o ring head seal
PostPosted: Thu Apr 27, 2017 12:37 pm
O rings work great. The machinist needs to know what they are doing to get the correct squish. I have never had trouble with gaskets, so i don't bother. :thumbup:
PostPosted: Thu Apr 27, 2017 1:10 pm
U know the specs? O ring and groove
PostPosted: Thu Apr 27, 2017 7:52 pm
Back when there were two stroke 250's used in flat track racing, the Suzuki X6 Hustler engines were the ones to use, with one critical mod, they became Twingles". The crank was rephased to fire both cylinders together, making the twin-single.
When I hung out at the late Jeff Bratton's crankshaft shop decades ago, I built a couple of H2R cranks for Erv, they were phased to fire as a "TRINGLE", all 3 at once, for his flat tracker H2R engined bikes
