It is currently Mon May 20, 2024 12:49 am
Post new topic Reply to topic  [ 76 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Mon Apr 09, 2018 6:31 pm
m in sc wrote:
almost ready... :lol:
Getting down to crunch time, I think I will bring my project even if I have to finish it there. ;)
PostPosted: Mon Apr 09, 2018 6:39 pm
Almost ready too :D :D
PostPosted: Mon Apr 09, 2018 6:52 pm
I'm waiting on three parts ordered for the RZ and need to rubber mount and hang chambers. Then, fill all fluids/ oil and fire up the new rebuild! Should have all this done by end of the week if all goes well.
“Jeff and Chris are THE MEN!”
RIP John E. Evans
PostPosted: Tue Apr 10, 2018 2:48 pm
STILL CLOSER...
AND A shakedown on the project rd went well, its ready aside from fitting a small fenderette. oil change in truck, change carrier bearing in 2 pc driveshaft and ready. :D
PostPosted: Tue Apr 10, 2018 3:30 pm
The brace you made on the RD is awesome. I don't see a tank so I guess you're mixing?
Like the work on the Suz fender - came out great. :thumbup:
PostPosted: Tue Apr 10, 2018 3:46 pm
thanks. oil tanks add weight. i should be under 250(!)-255 wet on this thing. maybe less. :mrgreen: the weigh in at wheelers should be interesting. last year was 261. ive changed a LOT of little things on it.
PostPosted: Sat Apr 14, 2018 7:58 pm
evansje1 wrote:
suthernS2 wrote:
What are you fixing John ? Your bikes looked and ran perfect last time I saw them.
Well, the girlie bike about once a month belches out some fluid. I took her clothes off to see if I can find where it is coming from. It usually happens at the same time she gets very moody.
Last year at the gap we did the Cherola/Dragon circle and I tried a top speed run on the level ground between 143 and 129 on the Daytona. She ran up ok in 5th but when I shifted into 6th it would not pull up any more speed. I pulled the top to have an inspection and found this. See the crack? I talked to Chuck Q and he advised me to find a pre Daytona head as it would be much easier for him to machine the combustion chambers for the proper squish and CCs for the over size piston. He bored and cleaned up the ports. I'm having to wait until I have a warm day to paint the top end before I can put it back together.
Daytona is back together, tuned, and pulling good. It has a little different appearance with paint on the pipes and different heads. The RZ leak was found to be a loose clamp so she is ready to go. The Daytona still needs it's shifter shaft seal changed and I would like to put the oil injector system back on.
Looking forward to seeing y'all soon.
PostPosted: Sun Apr 15, 2018 12:10 am
Looks great!
PostPosted: Sun Apr 15, 2018 1:50 pm
had a scare few days ago that i scrwed up the transmission. turn out i only had incorrectly clocked the shifting gear racks under the clutch. all fixed,5 gears ready.
:D
https://youtu.be/9oq8Bt-GtyI
i need to get that tank painted.... :shock:
PostPosted: Wed Apr 18, 2018 9:29 pm
Wow Mark you build the sickest bikes :thumbup:
- oil tanks add weight :lol:
Please bring this bike! One of my all time favorites :D
