I didn't really want to get rid of these, but I am hurt and out of work for a while so some stuff has to go. For sale is a set of Brembo 2 pot calipers these are from a Ducati Monster. Also is a set of adapters to use them on a h1/h2. This is not a ready to bolt up conversion. Most of the major work is done but you will have to source hardware. There are also some spacers that need to be used between the caliper mounts and the brackets. I have some spacers cut out, but I noticed some differences side to side on my forks and rotor spacing. I never really did figure out what the issue was so I am not sure if the spacers will work for you or not. I will offer some after sale support in helping to make the spacers that you need if you can't get the right ones or these don't work.
These are setup for stock rotors, but they will most likely need to be thinned down to use them. I did have a stock thickness rotor between the pads for mockup but they were tight. Keep in mind that I am not an engineer and I have no idea if these are safe and will actually work. You are basically buying the calipers and I am throwing the plates in the box with them. Use at your own risk. I am looking for $140 shipped in the US. If you are outside the US it will be actual shipping. Thanks.
Calipers
Adapter plates
Plates and calipers on forks.
