It is currently Fri May 03, 2024 5:51 am
 Post subject: bikes & nos parts
PostPosted: Fri May 22, 2020 1:11 pm
anyone looking to buy 4 h2's and 100's & 100's of nos h2 parts?
i'd like to sell it all together.
 Post subject: Re: bikes & nos parts
PostPosted: Fri May 22, 2020 7:02 pm
You'd do better with this in the "for sale" section instead of the "parts wanted" section. Also, an approximate location in your profile helps with sales.
PostPosted: Fri May 22, 2020 8:59 pm
thx jim,
i haven't been on here for awhile. looks like it got moved to the for sale section. i had my profile & location here, looks like it all got deleted along with all my previous posts.
how do i update my profile?
PostPosted: Fri May 22, 2020 10:31 pm
i have 3 '73 H2A's.
One is running w/title, rode it today. gold, original paint, pipes. runs strong, shifts good. needs petcock rebuilt. needs cleaned & polished. i just bought it yesterday from a guy that bought it in '73. i been buggin him for 10 yrs to sell it!
i got a h2a parts bike with it. pretty rusty, but has some good parts. air cleaner, chain guard, speedo w/only about 2,000 miles on it. engine is seized, but cyl. have no broken fins. it is a rolling bike with engine, pipes, carbs, etc. No title
i have another h2a i have been slowly restoring. Frame blasted & painted. No title. I have pretty much all the chrome re-done, rims, shifter, kickstart lever, handlebars, brackets, etc.
i have a '75 H2c w/title that needs restored. had it since early 80's when crank seal went bad & i parked it. like a dummy i painted it blue back then. it was maroon originally. no original pipes, have dencos.
i have a red '75 gt 750m. real nice, i restored this about 6 yrs ago & rode it alot. crank seal went bad. i have had crank rebuilt, engine cases vapor blasted, trans gears cleaned & inspected, ready to re-assemble. i have all gaskets & seals needed. i have nos piston & ring assblys, need to get cyl. bored to match. i had cometic make me a custom copper head gasket. lots of new chrome, new seat, original paint. i have stock pipes & chambers for it.
some of the nos h2 parts i have. i have multiples of some of these parts.
too many to list here.
dual disk kit- complete w/assbly & parts manual.
h2a purple body set-complete w/exrta right side side cover. new cap for tank.
seat
headlight & taillight assblys.
speedo's
tach's
ign switch w/#685 keys & fork lock
h2a & h2c oil pump to engine oil pipes w/banjo bolts & washers.
oil pumps.
h2a & h2c side cover emblems.
chain oiler.
spark plug holders & covers.
head bolts & washers.
main wiring harness's & handlebar & gauge harness's.
steering damper knob, plates washers, etc. complete.
hydraulic steering damper.
voltage regs. & rectifiers.
spark plug boots & springs.
ball brg clutch release w/correct oil seal.
h2c check valves
too many bolts, nuts, washers, springs, etc. to list.
too many rubber dampers, cushions, etc to list.
rear sprockets, frt sprockets.
air cleaner 3 into 1 boot w/all clamps
air cleaner canister w/mounting screw, w/snorkel & spring.
lots of cables-speedo, clutch, throttle, starter, tach.
clutch, cdi, & oil pump covers.
motor mount bolts
shift pedals
handlebar switch housings
This is just a fraction of what i have. Brian H. has seen alot of my parts lists that i emailed him awhile ago.
i have hundreds & hundreds more!
I have some nice early cylinders w/pistons & rings ready to bolt on.
rebuilt crank by Damon
several engine cases.
trans gears, shift forks, etc.
nice 34 mm mikuni's w/intakes & clamps
im still going thru stuff to inventory.
maybe i can post my written lists here if there is interest.
i would really like to sell it all together.
my health is crap. i have the dreaded COPD & cant breathe is only reason why i'm selling this stuff.
carl
PostPosted: Fri May 22, 2020 11:09 pm
PM sent.
PostPosted: Sat May 23, 2020 1:08 am
PM sent. please read. I'd like to have the first right of refusal for all.
Skyguyz
PostPosted: Sat May 23, 2020 6:12 pm
PM sent
PostPosted: Sat May 23, 2020 9:06 pm
If you don't sell it altogether, I'm interested in the H2A purple body kit.
PostPosted: Fri Jun 05, 2020 11:52 am
Pm, or call me 831-710-1194
Danny
