It is currently Tue May 14, 2024 5:16 pm
PostPosted: Sat Dec 29, 2018 5:48 pm
I have a large group of most H2 (and a few H1) parts. After 20+ years of collecting, I have parted with all my triple bikes and have this remaining good sized group of used (and some NOS) parts left to part with. Ideally, would like to sell everything in one large group, but if it comes down to it, I will sell off individual parts. See basic list below - email me if you want the full list with quantities.
(No tanks, sidecovers, seats, rear fenders, or gauges left)
Rear Brake Lever
Shifter Lever Assembly
Side Stands
Rear Brake Rod
Front Brake Lines/Manifold
Front Brake Hose
Front Brake Bracket
Front Brake Pads
Headlight buckets (metal)
Headlight rings/bulbs
Petcocks - non-triples
carburetors (H2)
carburetor parts - springs,sliders, caps, clamps
carburetor (H1)
carb filter Pods & clamps
Ignition Coils
horns
Misc Wiring Harnesses (approx 10)
Rear Brake Switch
Bar controls
Throttle controls/grips/misc
turnsignals
reflectors
turnsignal lens
group misc turnsignal posts
upper triple tree mounts with bar risers
Lower triple trees
triple tree handle bar risers
triple tree clamp parts, headlight ear rings,
battery boxes - bare
battery box - with regulator
CDI Bank
Regulators
Stators/parts
Rear Shocks H2
misc gauge wiring harness
throttle/control pieces
seat latches
gas tank caps
axles/motor mounts/bolts
steering damper adjuster assembly
misc cables
oil injector with lines
oil injector no lines
chain oilers with tanks
chain oilers
steering dampers
lots of bags of grommets/straps/bolts/nuts/misc
oil tanks
handle bars
Front Fenders
exhaust brackets
Exhaust head pipes/collars
handlebar/controls/risers/brake hoses
Sissy bars/backrests
tail brace
tail filler
taillight housing
oil tank bracket
Rear wheel hub
rear wheel sprocket
rear wheel hub dampers
misc rear wheel parts - adjusters, etc
Rear Wheel (1 with swingarm/sprocket/hub 1972)
1974-75 H2 Swingarm
H1 Partial Motor/parts - 1973 upper/lower case with shifter forks, 2 sprocket covers, 1 clutch basket, 1 clutch cover with oil pump, oil pump lines
H1 misc parts - gas cap,rear brake lever, kickstart lever , carb boots, cables,
1974-75 H2 rear plastic fenders
Exhaust Baffle Tubes
H2 Clutch basket housing (no clutch plates)
New windshield that I think was for an H1 (Plexifairing by National Cycle, Plexi3 Tint, #N8623/NC8623
H2 Sprocket cover
Clutch Releases
Seat hinge pieces
Frame Grip/handle
Forks Lock cylinder
head Bolts
Exhaust Chamber Collars + springs
Footpegs
Front Wheels
Rear Wheel
Front Wheet Dust covers
Front Forks
Group of NOS & used parts (working on list)
PostPosted: Sat Dec 29, 2018 7:03 pm
PM sent
PostPosted: Sun Jan 06, 2019 11:06 am
pm sent
1973 Z1
1974 H2 750
1976 kz 1075cc ATP turbo
PostPosted: Tue Jan 08, 2019 4:27 pm
Pm sent
