I just looked at three H2 disks, and they all appear to be the same, with three rivets lining up with three bolt holes, but I didn't measure to see how accurate that is.
I was only wondering, since I know on the front hub that came on my h1 the disc mounting holes are not the same(inline) with each other from side to side. No big deal with a single disc or dual stockers, but if one had 2 of these modded discs on the front it would drive me nuts not seeing the cut outs the same from side to side. Yeah I know OCD
If doing on a laser, I don't think it would be a problem if the mounting holes lined up with the rivits or not since each one would have to be setup individualy(at least I think). If I were going to machine these on a cnc mill, I would probably setup a block in the vice with the rotor bolt hole pattern. If the rotors are all the same you would only have to really setup the first rotor, the rest would then just be bolting them to the plate.
