It is currently Tue Jul 15, 2025 12:38 pm
 Post subject: WTB 74 H2 cylinders
PostPosted: Wed Aug 09, 2023 8:32 pm
Looking for a set of cylinders for an H2B. I have some, had new pistons fitted, but there was a problem with them so I have to find a new set. I will have them bored and the new pistons fitted. Pistons are 72.5 mm, so anything I can have bored to fit them will work.
Dave
 Post subject: Re: WTB 74 H2 cylinders
PostPosted: Thu Aug 10, 2023 7:38 am
You may find that if you measure your existing cylinders and their ports, you can use them along with either a spacer at the top or bottom, depending of whether you want stock porting or non-stock porting.
PostPosted: Wed Aug 16, 2023 8:35 pm
After much searching and advice I'm going to work with what I've got. Going to be interesting.
Thanks
Dave
