It is currently Sat Jul 05, 2025 7:27 pm
PostPosted: Mon Jul 21, 2014 3:29 pm
Hi All,
we have also a own ball bearing clutch pusher for H1 and H2 with SKF bearing. For board members only it costs 35 USD plus shipping outside Europe.
In Europe you have to add VAT.
All the best from Germany
Ralf
PostPosted: Mon Jul 21, 2014 4:24 pm
Ralf, Ralf, Ralf.....What are we to do with you?
I know you have must pictures to share, right?
Price sounds pretty good to me.
PostPosted: Tue Jul 22, 2014 3:30 pm
Hi All,
here are two pictures of our ball bearing pusher.
All the best from Frankfurt
Ralf
PostPosted: Wed Jul 23, 2014 6:33 am
When using the ball bearing pusher in an H2, is the ball still installed between the rod and pusher or is the length of the pusher compensated for removing the ball? :think:
PostPosted: Wed Jul 23, 2014 7:31 am
The one I bought from Chris Ritchie was the same length as stock and used the ball.
I would think that you absolutely want the ball in the system.
PostPosted: Wed Jul 23, 2014 10:56 am
You do want to run the single ball bearing between the pusher and push rod, and add one to any setup that doesn't have one as well.
PostPosted: Wed Jul 23, 2014 5:02 pm
It has the same length like the stock one,
Regards
Ralf
