A major concern and problem area with Triples is with oil line
check valves. Defective
check valves can leak causing excessive smoking or even bent rods from hydrolocking. Stuck valves can prevent cylinder oiling. The spec for crack pressure was increased from early (pre '74) valves from 2.8psi. Early
check valves can easily be disassembled and cleaned.
New
springs are now available along with new
check balls for early
check valves from members of the KTOG message board. This eliminates the need to make a test setup and reset
springs for proper crack pressure. Here is a link to the KTOG thread:
http://kawasakitriples.myfastforum.org/ ... 7790#37790Here is a copy of that content:
Newly manufactured
check valve springs made from phosphor bronze averaging 4.5 to 4.7 PSIG relief pressure. These
springs have the small diameter on one end to "hold the
check ball". Stock outside diameter and inside diameter and stock wire size. $5.00 each
New Chrome Steel
check balls 0.125” (stock) diameter. $1.00 each
Shipping to the Continental US via USPS (in protective poly tube inside a bubble wrap envelope) = Free
To order please PM or email 12dot
tv4fish@earthlink.net or Darth
jimshreve@dcsamerica.com … your choice.
