It is currently Tue Jun 17, 2025 7:25 am
PostPosted: Sat Jun 16, 2012 10:47 am
I've seen several posts recommending that a fuel resistant grease be used on the petcock's 4-hole gasket. Ordinary greases, including silicone grease, dissolve quickly in gasoline, so I searched around for a lubricant that is really "fuel resistant". I found a product called "EZ Turn", used in the aviation industry. As I understand it, it replaces an earlier product called "Fuel Lube". I got a 5 oz. tube from http://www.aircraftspruce.com/catalog/cspages/ezturnlube.php for $11.85, plus $3.65 shipping.
It's a bit thicker than typical grease, and since it doesn't dissolve in fuel, it will probably be good to smear on things like float bowl gaskets as a sealer/anti-stick. I may try it on one side of my clutch cover gasket, with sealer on the other next time I have that off. I would think it should be used in thin coats so a glob doesn't break off and clog something up downstream.
PostPosted: Thu Jun 21, 2012 4:35 pm
You're my new idol Jim. :) Great job of finding new products for us to use. :thumbup:
PostPosted: Thu Jun 21, 2012 4:53 pm
I'm not sure I want to be anyone's idol, Buddy, it sounds like too much responsibility. :lol: I just figure if I find something I need for my H2, someone else might need the same thing. If it helps, it was worth posting. :-)
PostPosted: Thu Jun 21, 2012 7:51 pm
Hmmm..... good for FF? :o
“Jeff and Chris are THE MEN!”
RIP John E. Evans
PostPosted: Thu Jun 21, 2012 7:52 pm
Hmmm, maybe more appropriate for CH.
PostPosted: Thu Jun 21, 2012 8:09 pm
Jim the "lube" guy!
