It is currently Sat Jul 05, 2025 9:23 am
PostPosted: Sun Jul 28, 2019 12:09 pm
Replacement oil lines for the "72-73" H2 750, these are flexible, the lines are made a little longer so you can cut and fit it to your liking, you will have to provide your own serviceable check valves and banjo fittings.
Just to note that these line are handmade so if you are looking for factory quality these are not, they still look very nice and function as they should without any problems but if you are a perfectionist "no"
Instructions
Install the check valves on the oil lines, get them in the position you want, bolt down, bolt the banjo fittings to the pump in the position you want. Measure and cut, I would cut them 1/8" longer so you have room if you miscalculate. Boil some water, get something that will flare the end of the oil line so you can push the banjo fitting on. Put the compression band on the line, put the end of the line in the water for a minute, flare the end and push the fitting on. DO NOT use a heat gun as it will not give you a tight fitting. Mount the banjo to the pump in the right position. Put the banjo fitting between two pieces of rubber in a vise with the oil line pointing up, pull the compression band down, use a pair of needle nose pliers, put the pliers between the oil line on top of the compression band and tap the band down.
1 set (3 lines) $150 + $7.90 shipping inside the US. UK. shipping $31 includes tracking and confirmed delivery. If you live anywhere else I would have to calculate.
