It is currently Tue May 21, 2024 11:38 am
 Post subject: Battery Charge Monitor
PostPosted: Sat Jul 25, 2015 9:06 am
Here is something I found on another board that was interesting to me and maybe so to others. It is an LED battery voltage monitor that will easily connect to battery terminals and mount in the late triples dashboard.
LED colors change depending on battery/charging state.
http://www.ebay.com/itm/200843083721?_t ... EBIDX%3AIT
Mounted:
Quote:
New addition to the idiot lights. The LED can be programed to monitor the bikes charging system. Six different options. Mine stays green when the volts are above 13.2, flashes green from 13.2 to 12.5 then changes to a blinking yellow light from 12.5 to 12.1 below which it flashes red. I like it better than the rubber plug that was there.
It took trips to just about every source I could think of in Ottawa to find the plastic insert to mount the light into. Snaps right in.
Other options: http://gammatronixltd.com/epages/bae94c ... /Category1
