OutsiderS2-H1 wrote:
I don't really know anything about the motor, other than it has had the heads shaved and I am pretty sure the tops of the cylinders have been cut too.
That's a good sign that other port timing changes may have been made too.
Quote:
It is .050 over and I believe the crown of the piston has been cut around the edges as well.
That's not a standard overbore, so maybe you mean .5 over (?) The increments are .5mm, 1mm, 1.5mm, etc., which works out to about 0.020" over, 0.040" over, 0.060" over, etc..
Quote:
I have had the H1 since 1994 but bought the engine and such in 2007 and it was in a drag bike. I really question though whether it was ever ran because the VM34's had stock H2 jetting (97.5) in it.
My VM34s use a different series of jets from stock H2 jets. I didn't know any VM34s could use the stock type. My main jets are #240. Are you sure they're VM34s?
Quote:
One of these years I hope to get it at least somewhat figured out. I don't expect it to be nice and docile around town but right now I can't decide whether or not the low end and midrange is too rich or too lean...
The usual way to figure that out is to push the starter lever. If the engine is stumbling and it gets better when you do that, it was too lean. If it gets worse, it was too rich. But if that's a highly ported drag motor, what you're feeling may not be due to the wrong jetting, it may be what you're stuck with, short of adding reeds.
