Well a big WTF? The new faces have cracked just like the last ones. The only thing I can figure is it is the Loctitie, the screws have very little pressure on them. I have used Loctite before on decal plates and never had this problem. The holes on the plates seem to have closed up around the screws, meaning the screws went right through the holes when they went on but had to screwed out of the holes when taking the plates back off? What else could it be? I am just going to send the whole shebang off to CB750faces and have them do them, and move on to other stuff.
Plan "B" was put into effect and these reproduction units I had will do until I can get the OEM meters straightened out.
Speaking of plan "B" I ended up finding a tank on Ebay and scraping the idea of painting the leaker I soldered after talking it over with The Painter. He got the tank fairly well prepped and I installed the Caswell Liner. It will go back to him Monday for paint.
The Electronic Ignition and new Coils went in too. The coils come with wires and the cylinder numbers already on them.
Clutch cable got shortened and installed for the low bars. I use the Motion Pro Kit for this and have had good luck. It has just about every cable end you could need and will most likely get used again for the throttle cables.
Also got started on the carbs and did some plating and Yellow Chromate on the linkage assembly parts. Of course after all the plating stuff was shut down I realized I forgot the Choke Levers, so they will need to get plated before the carbs can be assembled and mounted. Hopefully, that will be next weekend.
