As I have said before I helped a new friend by rebuilding his H2 last winter and we have been able to ride together a number of times, and we have swapped bikes back and forth. I have found this to be enlightening comparing one to another. As my H2 experience is very limited.
His H2 has Factory pipes and UNI filters and mine has Spec II pipes and UNIs with my patented velocity stacks. His has correct as possible jetting and mine has an Ivan's jet kit.
When you compare, his is quite a bit faster, the front end is coming up in the lower gears anytime you give it a reason to and mine though quick is not so wheelie happy.
They both move down the road good at highway speeds but mine takes more throttle to speed up between 4500 and 6000.
Mine pulls way harder in the 2500 to 3500 speeds.
His is faster, it is obvious from the butt dyno.
Until we ran them off ......., mine pulled his 4-5 bike lengths when we kept them on the boil.
Obviously his has more mid-range and mine has more top end, by quite a bit.
But as the saying goes "there is no free lunch" the top end comes with the expense of mid-range.
If it ever cools down we will trade pipes and verify the difference is the pipes.
I also have a set of stock pipes out in the shed and I will try those somewhere down the road.
