It is currently Sat Jun 21, 2025 5:47 am
 Post subject: S2 bore clearance
PostPosted: Fri Mar 02, 2012 7:56 am
Hi all,
The old books are giving me some conflicting info in regards to setting bore clearances on an over bore for my 350 s2. Pistons are cast Kawi NOS. Any suggestions?
Thanks
1975 H1
1974 S1
Yamaha RZ350
...and a smelly Honda CB350-Four
 Post subject: Re: S2 bore clearance
PostPosted: Fri Mar 02, 2012 8:05 am
To get the ball rolling, .002", but check with others! (Measure at the correct place!)
PostPosted: Fri Mar 02, 2012 8:44 am
.00106" to .00138"
PostPosted: Fri Mar 02, 2012 8:47 am
Oooh, that's tight, but then I am a H2 man! Anyone else?
PostPosted: Fri Mar 02, 2012 8:50 am
tripletriplenut wrote:
.00106" to .00138"
I wouldn't of believed it, if it wasn't in the factory manual! :o
PostPosted: Fri Mar 02, 2012 8:52 am
thats what i have my 350 set at the 250 is even tighter .00047 to.00079"
PostPosted: Fri Mar 02, 2012 8:59 am
^ Now that is fr****g tight! Wouldn't have believed it, but there you go! What temp was it that day! :lol:
PostPosted: Fri Mar 02, 2012 9:32 am
This is great stuff and Thanks guys! !
Last year I put .001" clearance into the tiny 45mm S1 bores -- it ran nice and quie and happily tolerated regular floggings w/o ever squeeking.
Also,.. last year, I got into a somewhat heater discussion w my boring guy about where the piston should be measured. Does the Kawi bible refer to this as well?
1975 H1
1974 S1
Yamaha RZ350
PostPosted: Fri Mar 02, 2012 9:39 am
It does, but I'd have to look it up (How far up from the bottom). Actually, I feel better about running .002" on my big H2 pistons, now, but I guess you can learn something every day! It will still rattle tho! (H2 that is!) :lol:
PostPosted: Fri Mar 02, 2012 12:04 pm
.0015 inch for stock cast pistons (one and a half thousandths).
