It is currently Tue Jul 15, 2025 4:28 am
 Post subject: O-ring 92055-035
PostPosted: Mon Nov 07, 2022 6:07 pm
Does anybody know of a suitable replacement, maybe from an auto parts store to avoid paying $10-$15 for this o-ring? This fits behind the sprocket, between the spacer and the roller bearing as pictured.
Part #92055-035
 Post subject: Re: O-ring 92055-035
PostPosted: Mon Nov 07, 2022 7:01 pm
Do you have bearing shops over there.... easy to find, hardware, auto-parts, etc?
PostPosted: Mon Nov 07, 2022 8:50 pm
Rod I might be able to find it at an auto shop. I don't think we have any bearing shops on Oahu.
PostPosted: Mon Nov 07, 2022 10:00 pm
If you have the old one, auto parts store, as noted, bearing houses, and, your local hardware store. Although the one you have is metric, the U. S. Measure ones will work just fine, they are both close to rack other. Also, on the seal race (collar) one end should have a larger "champher" to accommodate the O Ring.
PostPosted: Mon Nov 07, 2022 10:17 pm
I'm assuming the O-ring should be viton.
PostPosted: Tue Nov 08, 2022 5:22 am
There was no Viton back then. Buna-N was what was used. Viton would be better.
Make sure the O Ring goes up against the bearing, then collar, with that larger taper twirds the O Ring. In the diagram, the red arrows get it where it should be. I don't recall any FDM on that, but putting the O Ring between the collar and sprocket makes for a leak source that is somewhat hard to find.
"FDM" - 'Factory Directed Modification'. There are also regular SB, Service Bulletins, they change parts and procedures as needed. An FDM is always a change to parts, parts placement, procedures that must be adhered to. Remember, SB, FDM weren't usually available to the public, nor motorcycles, they were to direct service persons to revise correctly.
The Resources website used here is excellent in having SBS and FDM's available.
PostPosted: Tue Nov 08, 2022 7:45 am
ID = 22mm ID - 1.5mm thickness
PostPosted: Tue Nov 08, 2022 10:44 am
McMaster-Carr has them for less than $10 for a pack of 10, but shipping will double that unless you're already placing an order anyway.
https://www.mcmaster.com/9263K587/
PostPosted: Tue Nov 08, 2022 10:55 am
22mm is .865. 1.5mm is .060. Not rounded off, close enough to work for us.
PostPosted: Tue Nov 08, 2022 12:28 pm
Metric "O" rings are readily available in auto parts stores.
