It is currently Mon Jul 14, 2025 10:21 pm
PostPosted: Sat Feb 13, 2021 6:26 am
Any easy to apply spray paints people have had good luck with holding up to brake fluid? Like to get it painted since I am rebuilding master anyhow.
PostPosted: Sat Feb 13, 2021 11:18 am
Durabake by Duracoat. It's a semi gloss black that you bake in the oven for 15 minutes at 350 and it's the perfect match for factory black and it is impervious to chemicals. It's all I use.
I can't make the link hot for some reason.
[urlhttps://www.duracoatfirearmfinishes.com/durabake-enamel-p/durabake.htm][/url]
PostPosted: Sat Feb 13, 2021 7:27 pm
I’ll look into. Not sure the old lady gonna like me using her oven for that though :D
PostPosted: Sun Feb 14, 2021 12:24 am
B.B.Q. is my go to baking oven......... (of course!). Retired painter here, the slow heating and Cooling Down process is important. You can actually cook food on a BBQ, too! :D
PostPosted: Sun Feb 14, 2021 1:57 pm
I have not seen them in a while but I was a big fan of the PJ1 paints. I use an old toaster oven for baking small parts and the BBQ for larger pieces.
Rustoleum Professional is not bad either. As for brake fluid the best thing to do is switch over to DOT5.
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Sun Feb 14, 2021 6:46 pm
I can tell you for sure that Imron isn't damaged by brake fluid. I'd guess that any good polyurethane paint isn't either.
PostPosted: Mon Feb 15, 2021 3:43 pm
I was thinking of going over to dot5 since the entire system is cleaned out. Rebuilt master and caliper and hoses. Would make my problem go away easier. Then I could just use some of the paint I have handy
PostPosted: Mon Feb 15, 2021 4:04 pm
Be very careful when using DOT5, it is silicone based, but also holds air bubbles fairly easily, not easy to get the really tiny bubbles out. IT DOES NOT LIKE BEING BLED TOP TO BOTTOM, best to bleed bottom to top INTO the master, SLOWLY.
DOT 4 is OK, works for most systems very well.
PostPosted: Tue Feb 16, 2021 11:04 am
Yes, DOT5 can be more difficult to bleed but IMO it is worth it when working around expensive candy paint.
Jim
Atlanta, GA
1974 H1
1976 KZ400
1979 XS650 Cafe
1982 GPz750
2001 KZ1000P
1965 Mustang
1967 Triumph GT6
1976 Bronco
PostPosted: Tue Feb 16, 2021 11:56 am
Guts- does the gun paint need self etching primer after stripping the master cylinder and before painting?
I ordered some Wheelers Ceramakote instead of your recommendation due to cost for a couple of master cylinders. I also have a handgun barrel that needs repainting.
“Jeff and Chris are THE MEN!”
RIP John E. Evans
