It is currently Tue Jul 15, 2025 4:28 am
 Post subject: front end swap
PostPosted: Thu Apr 16, 2020 5:18 pm
whats the best and easiest front end swap to convert early H1 drum brake to disc
thanks
 Post subject: Re: front end swap
PostPosted: Thu Apr 16, 2020 5:23 pm
H1B onwards and any H2 should swap and bolt on. I bet someone here would straight trade a disk setup for your drum front end.
PostPosted: Fri Apr 17, 2020 2:07 pm
From what I've read from this board, ideally you want to use the lower tree from the H1B in order to maintain the correct (same) geometry as the 69-71 when upgrading to the disc-brake set-up. The rest of the parts - forks, axles, calipers, etc., from all other models should work fine as pointed out.
PostPosted: Thu Apr 30, 2020 6:45 am
Ok thanks for the replys
so just to confirm....are we saying its the lower tree that changes the geometry and not the frame headstock .its just that its easier to find latter ones ,D,E,F than to find a B type ....thanks for your help
PostPosted: Tue May 12, 2020 8:44 pm
Darn, I just can't recall...it's been awhile since I learned of this detail in lower clamps. I hope others will chime in with a definitive answer. In the meantime I'll search around to see if I can find more information.
Update:
Here's a couple links regarding this topic:
http://kawi2strokes.com/forum/viewtopic.php?f=2&t=2852&p=28115&hilit=h1b+triple+clamp#p28115
http://kawi2strokes.com/forum/viewtopic.php?f=2&t=2866&p=28211&hilit=h1b+triple+clamp#p28211
http://kawi2strokes.com/forum/viewtopic.php?f=26&t=11890&p=118336&hilit=h1b+triple+clamp#p118336
PostPosted: Sun May 24, 2020 4:28 pm
Thanks for that info Kawi3cyl
PostPosted: Mon May 25, 2020 9:46 am
The triples all have parallel trees. IE the forks are parallel to the steering head. It's the distance from the steering head center line to the center of the forks that is the critical for the trail.
There is a calculator on Dales site.
PostPosted: Mon May 25, 2020 2:30 pm
now the hard part,.........trying to find H1b steering parts
PostPosted: Mon May 25, 2020 9:35 pm
If you cannot locate the upper and lower trees over there (to avoid overseas shipping costs), just send me a PM - I may have both trees in my garage.
PostPosted: Fri Jun 05, 2020 12:14 pm
Pete, this is all I have available, all threads good, no steering lock:
