It is currently Tue Jul 15, 2025 8:29 am
 Post subject: Early H2 oil lines
PostPosted: Tue Jun 25, 2019 2:34 pm
Hello, I'm in the process of making new oil lines for the early 72-73 H2 750, the problem is I do not have a set of these oil lines to copy from. If someone has a extra set that they don't need and can send to me i would appreciate it, it doesn't matter if they are cracked or leaking and I also would need the serviceable check valves and banjo fittings so I can line up the valves correctly, I only have one check valve to work with in order to make them. I will pay for the shipping and in return I will send you a set of new oil lines once I start to produce them. Here are some pic of a H1 500 line that I made and the H2 lines will probably be the same once I start to make them. So what do you think, anybody interested?
 Post subject: Re: Early H2 oil lines
PostPosted: Tue Jun 25, 2019 4:25 pm
PostPosted: Tue Jun 25, 2019 8:20 pm
Yes! I'll send you a PM.
PostPosted: Sat Jun 29, 2019 7:49 pm
I sent Hoodyhoo a set of H2 lines. FYI, he's going to keep the banjos. My old lines were shot and I have another set of hardware to put on the new lines.
PostPosted: Sat Jun 29, 2019 7:56 pm
Glad you are on this hoodyhoo!
“Jeff and Chris are THE MEN!”
RIP John E. Evans
