It is currently Tue Jul 15, 2025 2:08 am
 Post subject: RIM ID
PostPosted: Fri May 18, 2018 4:28 pm
Can anyone identify this rim please, 302 ??
 Post subject: Re: RIM ID
PostPosted: Fri May 18, 2018 10:19 pm
When in doubt, check it out.
Valuable info is at your finger tips here.....
http://kawtriple.com/mraxl/tips/rimcodes.htm
Unfortunately 302 was not one listed as a triple rim, although it may very well be one
Wheel Rim Codes
TAKASAGO 185 X19 4K 303
First stamp is the manufacturer Takasago, then the rim size, then a number, then a letter, then 3 numbers.
The number after the rim size is the year the rim was made. 2, 3, 4, 5 etc....197(2) 7(3) etc.
The letter denotes the month of manufacture.....A-L. Jan- Dec.
The last 3 numbers tell you if the rim is H1 or H2 or other model. The H1's are 305 rear, H2 is 303, S3 front is 308, S3 rear 307.
S1/2=303 fnt
S1/2=307 rr
S3=308 fnt
S3=307 rr
H1=305 rr
H1/H2=303 fnt
H2=303 rr
KH250=308
PostPosted: Sat May 19, 2018 6:14 am
cheers for that :thumbup:
Its the 302 thats thrown me as ive not seen it before on a triple
PostPosted: Fri Aug 21, 2020 10:24 am
Wheel Rim Codes
S1/2=303 fnt
S1/2=307 rr
S3=308 fnt
S3=307 rr
H1=305 rr
H1/H2=303 fnt
H2=303 rr
KH250=308
Worth noting, the url link above did not work for me (as of 21-Aug-20). So, this post nailed it!
Thank you for this! Tremendously helpful. :thumbup:
PostPosted: Fri Aug 21, 2020 10:32 am
Correct link:
http://kawatriple.com/tips/datecodes/datecodes.htm
