It is currently Wed Jul 16, 2025 3:06 am
 Post subject: paint for 70 h1
PostPosted: Sat Dec 16, 2017 10:54 am
would like to spray one candy red color as opposed to 3 part formula..anyone done it?..paint numbers?
 Post subject: Re: paint for 70 h1
PostPosted: Wed Jan 03, 2018 4:29 pm
you mean nobody knows a close red paint code for a 70 h1!!!
PostPosted: Wed Jan 03, 2018 5:07 pm
I have no idea about paint codes... You won't easily get the same look as the original silver base/ dye red colour, clear, but it might be close with a lot of clear on it as a base coat/ clear coat modern system. The original paint system had to be carefully sprayed as the colour gets darker with each coat of the red, really have to do all three parts at once, in good light.
PostPosted: Wed Jan 03, 2018 6:45 pm
There is a guy in Arizona that sells paint for the triples can't remember his name :banghead
PostPosted: Thu Jan 04, 2018 1:19 am
Um, candy is always a 2 or 3 part. "Candy" is transparent, that shows the base through it. you ca't get that with a single non candy single step. HOC candies are what most use for a true candy paint job.
PostPosted: Thu Jan 04, 2018 8:22 am
http://kawatriple.com/paintmatch.html
PostPosted: Sat Jan 06, 2018 10:01 am
just want something simple close to a 70 red any paint numbers?
PostPosted: Thu Jan 18, 2018 7:53 pm
thanks change of plans
PostPosted: Fri Jan 19, 2018 3:24 am
Cool. It one of those things where you just have to look through a paint book. There are a million reds out there.
