It is currently Thu Jul 03, 2025 8:44 pm
 Post subject: H2 piston options
PostPosted: Thu Apr 21, 2016 7:21 pm
Looking for piston options other than wiseco. I am reading a lot of good things about wossner but I have no experience with them. Who's running them and how do you like them? Pros and cons appreciated.
 Post subject: Re: H2 piston options
PostPosted: Thu Apr 21, 2016 7:40 pm
Best pistons on the market! Totally changed over to them as soon as they were available, and the only pistons I recommend to my customers. :thumbup:
PostPosted: Thu Apr 21, 2016 8:00 pm
Wössner pistons are working very well in my H2, even though I cut gaping slots in them.
PostPosted: Fri Apr 22, 2016 5:57 am
What clearance do they recommend?
PostPosted: Fri Apr 22, 2016 7:42 am
0.0027" (0.07mm)
PostPosted: Fri Apr 22, 2016 9:24 am
Thanks for the input guys, I think I'll give them a try.
PostPosted: Fri Apr 22, 2016 7:36 pm
Hey Jim,
did you weigh your pistons before (and after) ?
Just curious, the difference.
Been Pondering about how to balance a Triple
PostPosted: Fri Apr 22, 2016 8:08 pm
Shane, I probably weighed them, but it's been a few years now and I'm sure I don't have the information, sorry. But obviously you can't cut slots for balance purposes! Usually you can remove a little material from places like the wrist pin boss, if they make a balancing pad there, or the underside of the piston crown. The first time I made my three pistons the same weight, which was around 1979, I had to grind the underside of the crowns of the heavy ones.
PostPosted: Fri Apr 22, 2016 9:09 pm
The Wossners are great, I just drilled two sets and they were still spot on weight wise. :thumbup:
PostPosted: Fri Apr 22, 2016 9:40 pm
But obviously you can't cut slots for balance purposes! Usually you can remove a little material from places like the wrist pin boss, if they make a balancing pad there, or the underside of the piston crown. The first time I made my three pistons the same weight, which was around 1979, I had to grind the underside of the crowns of the heavy ones.[/quote]
Jim, Here are a few pics of my Balancing Room:
An Ls9 from a ZR1 Vette. Had to add 200 grams of tungsten to get it to less than 3 grams of imbalance.
I've balanced numerous V8, V6, Inline 6 and 4's.
But never a Triple.
I know that the slots aren't for balancing but, it does change the rotating weight.
